Results 1 to 9 of 9
Thread: 2010 Camaro Injector Question
    I am wanting to upgrade the injectors in a 2010 Camaro. I have a few Questions.
    1: What are the stock injectors rated (flow rate at what PSI)?
    2: Is the injector flow rate vs. pressure the only table I need to change?
    I am putting in injectors that flow 52lbs/hr at 58psi......Does anyone have an injector table for this?
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Why are you going bigger? The stock injectors are 39 @ 58.
    If you are going to do this, get injectors that come with the correct data or you will be fighting is forever.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Jun 2008
    Charleston, SC
    969
    i agree
    Feb 2007
    San Antonio, TX
    1,255
    Quote Originally Posted by 30thta436 View Post
    Answer
    2. No there are several others (Greg Banish DVD has all the data you seek though). You can literally copy paste the data you need. Summit.com Search Tuning DVD.
    What injectors did you purchase by the way, Manufacturer/Part Number?
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Jun 2005
    Southern FL
    2,044
    You also need to inform us of why you're upgrading the injectors? Unless you are running more than say 550 to 600 rwhp N/A, there's no sense in changing out the factory injectors. You must be going to forced induction?
    As for what size your injectors are, if you go by GM's factory 2010 Camaro and 2009 Corvette LS3 data, they are 45.14 at 58 psi. If you go by the factory G8 GXP data, they are 46.06 at 58 psi. If you go by the factory '08 C6 data, they are 41.74 at 58 psi.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    May 2008
    49
    Just for my info. Can't the injector sizing be obtained through reading the tune? Just curious in case I ever came across a car with unknown values off hand.
    98 TA
    06 1500hd cc 4x
    Jul 2009
    509
    Quote Originally Posted by RWTD View Post
    Mine are 41.6, assuming I'm not totally reading the data wrong.
    2016 GMC Sierra 1500 6.2L
    Jun 2005
    Southern FL
    2,044
    Quote Originally Posted by 99LS1SS View Post
    It's possible the beta I'm using is showing the wrong data. See here for an example of an older beta versus the newest one on a G8 GXP file:
    Code:
    	18.6	20.9	23.2	25.5	27.8	30.2	32.5	34.8	37.1	39.5	41.8	44.1	46.4	48.7	51.1	53.4	55.7	58.0	60.3	62.7	65.0	67.3	69.6	71.9	74.3	76.6	78.9	81.2	83.5	85.9	88.2	90.5	92.8
    	41.59	41.59	41.59	41.59	41.59	41.59	41.59	41.59	41.59	41.59	41.59	41.59	41.59	41.59	42.14	43.49	44.80	46.06	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81	46.81
    Newest beta below (now the values are completely different for the axis label):
    Code:
    	18.6	21.5	24.4	27.3	30.2	33.1	36.0	38.9	41.8	44.7	47.6	50.5	53.4	56.3	59.2	62.1	65.0	67.9	70.8	73.7	76.6	79.5	82.4	85.3	88.2	91.1	94.0	96.9	99.8	102.7	105.6	108.5	111.4
    I'll report it to support and ask them if it's a bug.
    Jun 2005
    Southern FL
    2,044
    Okay, the newest beta is correct. Here's the answer from Mr. Bill (thanx!!!):
    GM has changed the axis to 128-768 in steps of 20kpa.
    It affects some E38 & E67 operating systems from what we can tell. I know we did the Camaro def & we're working on the others (not sure if they were all done or not, I'd need to check our engineering tracking log).
