Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Read of BCM
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    Read of BCM
    Not sure if this has been requested already, but it would be nice if HPT could read BCM codes. For example, ABS errors. Not sure if it is even possible, but the Tech II can
    Really special if I could edit things in it. For example DRL's! (Probably not possible)
    Thanks for your consideration.
    All Motor 2001 GA GT1
    Aug 2004
    24
    Re: Read of BCM
    that would be kinda cool some more things to mess around with
    -Greg-
    Nov 2002
    Central Florida
    2,503
    Re: Read of BCM
    Yeah, and teach it to squawk out the "sport button" code
    (under some sort of electrical input) while yer at it!
    Oct 2004
    408
    Re: Read of BCM
    Quote Originally Posted by jimmyblue
    Was this request asking too much? The main thing I was looking for was to read the errors from the BCM. I didn't think this was an unreasonable request.
    Sep 2002
    Chicago, IL
    6,395
    Re: Read of BCM
    Reading codes from the BCM is not unreasonable at all.
    We'll look into it and see what we can do.
    We got this guy Not Sure, ...
    Oct 2004
    408
    Re: Read of BCM
    Quote Originally Posted by Keith@HPTuners
    Thanks Keith.
    Tuner kabbott's Avatar
    Sep 2004
    Ba co. Md
    121
    Re: Read of BCM
    Anyone familiar with this software
    http://www.autoenginuity.com/index.html
    need to read bcm codes on my impala and
    could also log my wifes POS ford.
    maybe 2.0 will read bcm? :huh2:
    any other software package availible that will read
    P,U,B And C codes from different makes with one interface?
    2000 Impala 3.8
    4T65Ehd 3.29
    VCM ID:7DS739259ui
    VCM OS ID:9387047
    Oct 2004
    10
    Re: Read of BCM
    I have AE and it is very good for the money. I bought it because it was so cheap and the Ford coverage was really good. They are constantly improving and adding new coverage. Still for all around coverage on multiple makes, a MT2500 or Solus with the 5.2 update is probably the best thing right now.
    I have about every one that Snap-on makes but I think you will be fine with the AE software. Jay is a good guy to talk to also.
    Sep 2004
    Ba co. Md
    121
    Re: Read of BCM
    Thanks for the input.I did check out snapon and others
    but like the tech 2 they are a bit pricey and hard to
    justify the expense for my use.plus it'll use my $2000 laptop
    for something other than reading this forum!
    2000 Impala 3.8
    4T65Ehd 3.29
    VCM ID:7DS739259ui
    VCM OS ID:9387047
    Sep 2004
    Ba co. Md
    121
    Re: Read of BCM
    Any new info on reading BCM codes Keith?
    2000 Impala 3.8
    4T65Ehd 3.29
    VCM ID:7DS739259ui
    VCM OS ID:9387047
    Nov 2004
    231
    Re: Read of BCM
    it would be good to be able to read bcm, any updates on this
    04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
    Oct 2005
    7
    Re: Read of BCM
    I belive all the DIC info is kept in the BCM on my 04 GrandPrix and I would LOVE to mess with that!
    Another vote for added features!!
    Aug 2004
    Qld Australia
    166
    Re: Read of BCM
    I seem to recall an intention for HPT to be able to handle most of the functions of a Tech 2. In due time of course...
    Brian
    Sep 2004
    Ba co. Md
    121
    Any new Word on this I really need to get somthing for this and it would be nice to use your hardware rather than another software package and cables........... and interface..more cables etc....
    all i really need at this point is a read of codes for wheel sensors and ride control etc.
    i would be glad to test anything you can come up with and i am not opposed to an upgrade charge for these features
    2000 Impala 3.8
    4T65Ehd 3.29
    VCM ID:7DS739259ui
    VCM OS ID:9387047
    Aug 2007
    1
    Im bringing this post back up to the top to see if the software can read bcms now. Thanks for all the help.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    No it will not read or edit the pcm, however you can read codes on any module on the same bus as the pcm/tcm.
    Is there any itent to add the functionality of being able to make changes to the BCM, etc? Let me give you an example. On a C5 Z06 the option for tire pressure sensors is shut off. Its in there, you just have to turn them on with the techII. On the auto transmission cars you can look at temperature on the DIC but not the manual. If you could access that you could set it up to look to the sensor to display the transmission temp.
    Here is an example of something you can do with a flash of other modules like the ABS controller.
    http://forums.corvetteforum.com/show...&postcount=130
    All C5 (from 2002) & C6 brake bias/pressure are controlled via the electronic ABS control unit. The 2001 C5 Z06/Coupe brake bias are mechanical valve control. The racing ABS/Bias calibration is not a "HP Tuner/LS1 Edit" thing. Its a GM Racing "Thing".
    Contact GM Racing for the C6R ABS/Bias calibration which is downloaded and installed by your dealer. This will disable the A/H and make the car VERY UNSTABLE on ice, snow or very slick conditions. This is because the bias is at 55/45 with the rears engaging a millisecond before the fronts. The street bias of 80/20 allows the car to be very stable under slick conditions. I am not sure how much of this will negate your existing warranty or GMPP.
    The C5R ABS/Bias calibration is not yet available but was told it will be in the near future. My 2002 C5 Z06 was done as a street/track mule with the final version of the calibration flashed into both of my C5 Z06s last December. An added note, this ABS/Bias calibration for the C5 is set to wheel diameter to be squared on all fours (295/35R18) not the O.E.M. staggered (265/40R17 & 295/35R18) wheel diameter. You WILL NOT have stable ABS/Bias brake control on a staggered wheel diameter with this calibration.
    Again, folks may not wat to open the pandora's box of allowing folks to play with the BCM/TCM/TCS, etc... but I was wondering if there were any plans to ever offer look into it...
    Thx...
    HP Tuners Support
    (foff667)
    28,268
    No plans anytime soon.
    Sep 2004
    Munich Germany
    48
    almost two years ago... anything new on this?
    I am planning to spend 2000 $$ to get a used tech 2 from ebay, but would rather like to spend some money to HPTuners to get the same features. And i guess i am not the only one
    Jun 2009
    Jax FL
    17
    Be careful which tech 2 you buy. There are many clones on the market. I bought a new one, quit working in a month, sent it to Bosch/Vetronix under warranty. They said I'm screwed because it was a clone-no warranty & they won't even try to fix it.
