Results 1 to 3 of 3
Thread: 2 BAR Conversion Question
    Tuner gr8vet's Avatar
    Aug 2008
    Sunny South
    53
    I am ready to move into the 2BAR tune on my 02 Vette.
    I have set up the VE table as per instructions.
    Once I convert over, will I see any drastic changes in the existing parameters of the tune. Or will the engine act pretty much the same, but allowing me more freedom to make the boosted areas better?
    Thanks in advance
    tt
    Aug 2008
    Sunny South
    53
    May 2004
    46
    The tune should be OK. You will need to do plenty of runs to fine tune the upper end VE table, but extrapolate from the initial runs.
    Make sure you reset the config file for the new MAP range and also the guages.
    I found a significant benefit upgrading to the 2BAR operating system.
