When will us 2003/2004 Silverado SS guys be seeing support for the 2/3 bar MAP sensor?
Nobody knows??? :huh2:
How much boost your at,isnt 2 bar good for 26lbs.
are you an existing user? If so then tell me your operating system, GM switched to a PCM with a larger memory (1024k) in 2004 so might be a chance your operating system is already supported.Originally Posted by jonmalibuss
Email me your VIN and i can check for sure.
BTW, 2bar is good for around 15 PSI boost (which is 210 kPa or 30 PSI absolute).
Chris...
I count sheep in hex...
