Page 5 of 7 FirstFirst 1234567 LastLast
Results 81 to 100 of 140
Thread: Wideband Accuracy: Facts & Issues
  1. #81
    Quote Originally Posted by Rockrz View Post
    OK, so what is "CL" and what is "OL" ?
    Closed loop and open loop.
  2. #82
    Advanced Tuner Rockrz's Avatar
    Aug 2008
    I'm right here!
    261
    Great, thanx...I guess I need to compile a list of things like this
  3. #83
    Nov 2008
    38
    I heard you couldn't permanently wire in the AFX? Something about leaving it hooked up too long will ruin the sensor or something?? Any feed back on this?
    1999 Camaro SS- 2004 LS6 from a Z06, SLP LT headers and ORY, SLP LS6 intake, SLP flow pac, Hurst short throw, RAM clutch, slave and billet flywheel, MSD 8.5mm wires, TICK MC on the way, HP Tuners
  4. #84
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    whoever told you that doesnt know what they are talking about...
    no issues with a permanent install of the AFX..
    just need to recalibrate the sensor once in a while(which may need to be removed from the exhaust to do the calibration or the vehicle needs to have been sitting for longer than 24 hours to guarantee clean air in the exhaust pipes...)
    and replace the sensor just like any other o2 sensor when they finaly do wear out over time
    -Scott -
  5. #85
    Nov 2008
    38
    Good deal!! Thanks for clearing it up. So the ECM widebands are good? How much do they usually run?
  6. #86
    Tuner boomer's Avatar
    Feb 2005
    Peoria, AZ
    128
    Quote Originally Posted by 99LS6SS View Post
    The only way that would happen is if you directly hook the controller up to a power source that is "Hot" all the time, like the battery. you just need to make sure its "key hot".
    Photos
    320 rwhp/340 ft-lb
    1/4 mile: 13.33 @ 105 mph
  7. #87
    Apr 2005
    4,387
    Quote Originally Posted by boomer View Post
    I think he understands that it needs to be an ignition hot just like the stock o2's run on ...thats kind of a given
    -Scott -
  8. #88
    Mar 2006
    Detroit
    1,027
    As mentioned before, it's fine as long as you use switched power and have the sensor installed at the proper angle.
    Yes, ECM is the standard of the industry. The price is "expensive" by enthusiast standards, but reasonable as far as lab grade equipment is concerned. They typically run somewhere between $1500-$3500 a piece, depending on which unit you're looking at. Considering how much shop owners spend on other equipment (dyno, software, hand tools, demo vehicles), it's really not that much to know that you're collecting good data.
  9. #89
    Tuner in Training Bow Tie 67's Avatar
    Sep 2007
    18
    Some quick questions, on a permanent install is it ok to shorten the jumper harness with good solder connections or best to just coil it up. When I add this sensor to the passenger side header, should I worry about its orientation in relation to the narrowband sensor?
  10. #90
    Advanced Tuner TXZ0603's Avatar
    Dec 2007
    Houston, Tx
    375
    I have the AEM UEGO WB. Should I replace the sensor with a diferent one and which one would work with that? Thanks
    2003 Z06
    Forged 347
    PTE Billet 67/65 Turbos
    FMIC / Dual 50mm Tial BOV's
    ID 1000 Injectors
    RSI Stage 4 Fuel System
    07 Z06 Cam
    Tripple Nozzle Meth
    ACT Twin disk clutch
    25# Boost
  11. #91
    Aug 2008
    I'm right here!
    261
    So, what happens if you don't use wideband O2 sensors?
    Do you just put up with a bad air/fuel mixture, or is the
    stock setup still going to provide somewhat decent bad air/fuel mixture
    I understand that stock wouldn't be as good as wideband, but I thought
    I'd ask this question to get an idea of stock versus wideband.
  12. #92
    Jun 2005
    Southern FL
    2,044
    Rockrz, what are you asking? If it's okay to datalog factory narrowband sensors in an attempt to dial in fueling?
    Short answer: ABSOLUTELY NOT!
    Narrowbands are only good for switching at stoich (whatever thay may be, depending on the fuel you're using), and can NOT give any proper data for anything other than such.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
  13. #93
    Aug 2008
    I'm right here!
    261
    What I was wanting to know is, what options are there
    for people NOT running wide band to try and get the best
    air/fual mixture?
    Do ya guess? Or, do you just hope the OE settings
    are decent?
    Just curious about the differences between running
    wideband O2 sensors, and running regular O2 sensors
    If I knew what the differences were between the
    two, I could better decide if it would be worth it
    or not to get into the wideband scene...
  14. #94
    Jun 2005
    Southern FL
    2,044
    I basically explained to you the differences. Narrowbands only read properly at stoich. Widebands can read basically any AFR you throw at it (there are low and high limitations, obviously). You can also Google or Bing search the info about widebands and narrowbands.
    So, no, you can't logically tune your car without a wideband.
  15. #95
    Feb 2008
    665
    Hell I dont even feel that tuning even part throttle areas with fuel trims is worth a crap IMO, got the wideband just tune everything, more accurate and no messing around with resetting fuel trims between changes and all that bs.
    2017 Silverado LTZ
  16. #96
    Feb 2007
    San Antonio, TX
    1,255
    Did the NO Wideband thing for over 1 1/2 years. Total waste of time and almost threw away my Hp Tuners Software due to the frustation resulting from lack of tuning ability. Thank god I caught on deal on my used Fast Wideband. Please re-consider buying one.
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
  17. #97
    Aug 2008
    I'm right here!
    261
    Quote Originally Posted by Cantalope Kid View Post
    What does this run, about?
    To be honest, I was just planning on advancing my timing a bit, controlling
    my electric fans, and maybe tweaking my automatic tranny to shift a little
    more firm, and that's about it.
    Is getting better fuel mixture with a wideband setup really going to
    increase my horsepower that much? I'm running a 4.3L V6 that is
    rated at about 200HP from the factory.
  18. #98
    Apr 2005
    33
    I called Ron at ECM yesterday, to find out the price and benefits of the Lambda Pro. He said the Lambda Pro runs $3,500. If you're on a budget, he highly recommends the NGK AFX with the NTK sensor. ECM designed the AFX for NGK, and he says that any negative reviews of the AFX are "full of s***."
    Ron said he has toured each of the manufacturing plants of the Bosch and NTK sensors. He says that although the Bosch is very good for the price, the NTK is more in price for a reason. The NTK has an intricate manufacturing process that greatly increases the durability and operating range (he went into specifics, but I can't recall enough information to speak intelligently about it). He said it can accurately measure to 2.5 for Alcohol, 5.0 for Gas, and is accurate to within 0.1.
    Needless to say, after 15 minutes of talking to Ron, I was very impressed with his knowledge on all this. I wish I had remembered more of the information to pass on.
    I also went ahead and finally bought the AFX with NTK sensor from Ballenger Motor Sports. They definitely have the best price I've seen anywhere.
    1999 Corvette
  19. #99
    Feb 2008
    665
    Quote Originally Posted by huttler View Post
    Good call on purchasing the AFX, you won't be disappointed. They can't be beat for the price as far as accuracy goes.
    2017 Silverado LTZ
  20. #100
    Tuner in Training AleroB888's Avatar
    Dec 2006
    Denver, CO
    25
    Quote Originally Posted by RWTD View Post
    How does the stock PCM get its data to attempt to achieve the target AFR at WOT?
    1999 GLS MP90 supercharged / 2003 GL MP62 supercharged / 2004 GLS stock
    Magnuson MP90 / TOG's / 3 in. Magnaflow exhaust / MSD ignition / LS1 MAF / Racetronix pump / HP Tuners / TCE 68mm TB / 36 lb Inj
    = Best track time: 12.951 @ 104.48, 1.839 60 ft. (Beech Bend Raceway Park, 11-23-13), 50 Deg. F
    http://www.youtube.com/watch?v=hpVYZPbpPzk
