I am trying to get a car tuned in 3bar SD and for some reason I the car will not go above 100KPa. any help on the subject would be great. here is my file and scanner config.
Scanner config doesn't help as much as a scanner log would however, Its probably either that you don't have your config setup the way the help file explains it or you are not using a 3 bar sensor. If you are using a 3 bar sensor go through the help file in the operating system section http://www.hptuners.com/help/vcm_edi...ters_gm_os.htm for more info on setting up your scanner for 3 bar.
bill I e-mailed you a log of the file. i made the changes you suggested in your previous e-mail but still no luck
Please post the log file, I'm not at my hptuners computer but am online where I can view any posts.
I converted it to a excel file.....how should I post it.
Please don't convert to excel, just post the .hpl file, use the manage attachements feature the same way you did for your original post.
Just by looking at your config I'm pretty sure like 98% that you probably have a custom PID set as your map sensor that is probably creating an issue so make sure you look them over.
well give me 2 mintues I will go log a quick run
uploading
yeah I'm an idiot......Originally Posted by Bill@HPTuners
doesn't look like you hit boost at all in that log but nothing looks wrong from what I can tell, again probably a custom PID issue.
how would I go about fixing that?
Either
a. fix the custom PID that is screwy
b. delete the custom pid that is screwy
c. go into your hptuners folder & delete the file named VCM Scanner.cfg
any one of the three will work.
the only custom PID in that config is the Air Fuel Error. I do not see a file named VCM Scanner.cfg?
It'll be in your hptuners folder under \My Documents\HP Tuners\Settings
And just because its in that config means nothing, the config you posted does NOT match what you scanned so when you are scanning you are NOT using that config you posted.
I now know for sure it is a custom PID that is screwy.
I have been using different log files trying to determine what my problem is, so the one I posted doesn't match the log I posted.
I deleted the VCM Scanner.cfg file and still no avail on the log file. it will not go above 100KPa. should that have fixed my problem? or now do I need to start deleting PIDs?
here is the latest log file using the original config that I posted
Also here is a Screen Shot of my PIDs
See that PID named Boost...
yeah, thats your issue.
