Results 1 to 10 of 10
Thread: Scanner Toolbar issue
    Downloaded the new updated and now my scanner shows up like this. Any ideas?
    I can still use the buttons, but obviously they require more effort than usual.
    Have you downloaded and installed Microsoft .net package ver 2.0?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    Weird, what operating system are you running? Can you post the text from a vcm suite infolog without your serial number & app key present please.
    -Bill
    HP Tuners Support
    (foff667)
    28,273
    Quote Originally Posted by NTIMID8
    2.0 must be installed for our software to even install itself, otherwise you will get a VCM Suite 2 requires the .NET Framework version 2.0 error.
    Jan 2005
    Mansfield, Ohio
    24
    I downloaded today and have the same issue. I only upgraded because I bought a new licence I have the serial unit. I thought the upgrade had my new license. after beating my brains out with a customer waiting. I now wonder if this was just a new version and my new license hasnt been made available. Just to add insult to injury now my scanner doesnt work right. I did re-use my old configuration could this be part of it. I didnt have to rebuild configs before.
    Operating System: Windows XP
    Microsoft .NET: 2.0.50727.1433
    VCM Suite Product: VCM Scanner 2.22.3036.17297
    VCM Suite ID:
    Year/Models:
    GM Firebird/Camaro (V8) 1999
    GM Firebird/Camaro (V8) 2002
    Single Vehicle VCM Enhancements:
    HP Tuners Support
    (foff667)
    28,273
    Na the .cfg file you are using has nothing to do with it, unfortunatly I have no idea what it could be, I tried a few different font & dpi settings & neither made this issue appear and on the 3 pc's I have here none of them show this issue, I'm loading our software onto a 4th xp pc I have here to see if it shows up but im perplexed to be honest.
    HP Tuners Support
    (foff667)
    28,273
    Tried my 4th computer & all work fine & show up as normal so I'm honestly not sure what the issue is I'll need to have our software designer look into it.
    Figured it out. I was using a custom theme and when I switched back to Windows XP theme, everything shows up fine.
    Jan 2005
    Mansfield, Ohio
    24
    OK I should have read the OP closer My issue is with the scrolling with the scanner. When reading the charts. WHen I open the scan all is fine. When I first start scrolling back and forth using the arrows or dragging the tab it works fine. After a few cycles like this the arrow that I have been using the pointer on disapears and i can no longer move around in the scan with the scroll bar. I can use the start and the pause only. Sorry I was a little frustrated with my license issue by the time I found the scanner issue. Wasted 4 hrs last night on this product and never got to tune the customers car.
    HP Tuners Support
    (foff667)
    28,273
    Ok so the toolbar issue is fixed with a simple theme change, Koolrayz please start a new thread in this section for yourself so I may help you better.
    Thanks,
    Bill
