where in the HPT Editor can I disable the tire pressure sensor monitoring system??
Thanks in advance.
Robert
Thanks in advance.
Robert
i dont think you can. i would imagine its in the bcm not in the vcm. i could be wrong though.
98 Camaro, M6, HPTuners, heads and cam
the tire pressure works through pass door module
OK. Then what? Are you saying the monitoring system can be disabled by accessing this PDM and doing something to it? Thanks.Originally Posted by ericguy320
Robert
RamJudd,
Did you ever figure out how to turn off tire pres. sensor feature? I have a friend that is wanting to do this.
Thanks,
02 Z06 Corvette-Procharger+upgraded air ducts,\"NW\"TB/FAST intake 90mm,Fuel pump/rails upgrade,42.5 lb Inj,1.8-Jessel Rockers,Hard P-rods,ARP-bolts,Heads P/P,.051 Cometic-gaskets,CR -.5,SS braided line
yes, I did. The only way to get this feature turned off in the programming is to take the car in to a dealer that has a Tech II. The feature IS in the Tech II, I know this for a fact. But I had to actually help the tech dig through the various screens on their Tech II to find it.
Robert
