Anyone care to share their closed/open loop timing
Anyone want to share their open loop/closed loop timing maps??
Post the mods too? That would be great to jumpstart tuning.
Re: Anyone care to share their closed/open loop ti
I am still playing with mine a bit, but here is where I'm at so far:
0.60 g/cyl - 1.20 g/cyl
11, 12, 13, 14, 16, 18, 20, 21, 23, 24, 28, 29, 30, 30, 28, 26, 24, 28, 28, 28, 28, 28, 28, 28, 28
I also had to fatten the fuel curve a bit. In stock form the car was running a bit lean. I was only getting 23.5 degrees at WOT, O2's in the .870 range, small amount of knock retard.
I added 3% fuel to PE and used the above timing curve. O2's are now in the .900 zone, 28 degrees at WOT, and no knock retard. I'm going to build a few different timing/fuel curves and take them all to the dyno - I will keep you posted
