Results 1 to 4 of 4
Thread: EGR disable...
    Mar 2004
    14
    EGR disable...
    i have the typical OBD2 emmission test where they just plug into the diagnostic port. No visual inspection. If i were to just click the egr disable, would this throw a code to their "reader"? Or could I just set the enable and disable mph to like 202 and 200 since I would never reach those speeds, and in theory, their "reader" would still see that the computer is awaiting those parameters? Same thing with the air pump disable coolant temp. What should i put that to so I can remove it without throwing an SES light. Thanks
    Chris
    Apr 2004
    Las Vegas
    73
    Re: EGR disable...
    I am having the same issue. I have a 2000 Z28 and removed the EGR when I put the LS6 intake on. I disabled it in General and set both the speeds to 0. I still get a code that says it cannot read the voltage. How do you totally disable?
    Thanks,
    Kane
    Feb 2004
    45
    Re: EGR disable...
    I was having a problem getting mine inspected, the car kept reporting "not ready" on a bunch of things, and if it had more than 2, it would fail inspection. I wen and turned off every DTC to "3-no error reported" and ses enabled off and it passed, didn't even sniff the exhaust or anything, guess the cats are coming off.....
    Apr 2004
    Las Vegas
    73
    Re: EGR disable...
    I finally figured this out also. Still learning...
    Kane
    Quote Originally Posted by keving
