Results 1 to 20 of 37
Thread: 05 c6 e40....best map sensor for 2.5 sd
    I have read that the GM pn 12580698 is a 2.5 bar sensor. I was told by another person that it is a 5 pin sensor with an integrated IAT. I called my local GM place and they told me its was 3 pin. To sum it up.....I am looking for the best 2.5 bar sensor to use with the 2.5 bar custom os for the e40. I dont want to buy the wrong sensor and pigtial. TIA
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    There is no 2.5 Bar sensor that is MAP only. The 0698 version is 2 bar (15 PSI boost) So unless you are going above ~15 PSI you are good. If you are headed for 2.5 bar (Max ~21 PSI Boost) you will have to get one of the old "brick" style 3 bar MAP sensors and run a vacuum line.
    Always Support Our Troops!
    Thats what I wanted to do but there is a 256kpa limit in the computer. I am looking to run over 15 psi.
    http://www.hptuners.com/forum/showth...1186#post81186
    People are mentioning this number as 2.5 bar map sensor. I wouldn't mind if it was 2.5 map and Iat. If the Iat was correct I could just use it....or leave it unwired if not. Right?
    Advanced Tuner Bluecat's Avatar
    May 2006
    Catlettsburg, Ky
    407
    Everyone says you can use a 3 bar map with the 2.5 os, but how? I understand that os still stops at 255kpa reguardless, but you can't even configure it for a 3 bar sensor. The map linear has has a max value of 256. Unless you can plug in a value around 300, I don't see how you can make it read correct.
    What's the purpose of the Linear B?
    You need to be careful with the Cobalt becuase they have 3 MAP sensors if i remember correctly.
    1. combo MAP + IAT goes in the manifold, 2.5 bar
    2. inlet air pressure (in the intake path) 1 bar i think
    3. baro sensor (2 bar i think)
    You should be able to wire up the 2.5bar MAP + IAT sensor and just not use the IAT part.
    The numbers for this sensor are linear 270.59 (the max you can enter is 256) and offset -3.30, which i think the min you can enter is 0. It will be close but not exact.
    In the later E38 ECM the limits are different and you can use a 3bar sensor no problems. I was getting confused between the two in a previous post as i was working on the E38 code at the time. Sorry.
    Chris...
    I count sheep in hex...
    Stumbled across this post so I figured I would add some info.
    A 3bar map sensor will not work properly. Since you can't enter a value higher than 256 it will always read incorrectly. (I had a 3 bar installed and read map values while applying regulated pressure to the sensor and a boost gauge). I'm sure you could install and use this sensor but your KPA reading will never actually be right.
    2 bar obviously only reads 2 bar, so a real 2.5bar sensor is needed.
    I found this sensor online-
    20-250kpa and inexpensive.
    http://www.freescale.com/files/senso...t/MPX4250A.pdf
    http://www.mouser.com/search/refine.aspx?Ntt=MPX4250AP
    Installed it in an 05 C6 with APS twins, re-tested with regulated air/gauge and it reads up to 256kpa while matching boost gauge values perfectly.
    28,272
    Thanks for the info, I think I'll sticky this thread
    No problem.
    Aug 2004
    Franklin,OH
    215
    So I am just checking before I go ahead and order this for a customer. Is the above freescale sensor the way to go with the custom 2.5bar os?
    Dec 2005
    Sydney Australia
    510
    yep that sensor is a true 2.5bar, it is used in a lot of after market ECU's here in aus and works a treat
    Tuner TYRFRYR's Avatar
    Mar 2007
    Southern Louisiana
    69
    Quote Originally Posted by EC_Tune View Post
    Is this a brick style sensor or does in fit into the MAP port on the LS3 intake maniflod ?
    Nov 2005
    Houston, TX
    3,968
    fits in the manifold.
    Bill Winters
    Out of the LSx tuning game
    Mar 2007
    Southern Louisiana
    69
    Thanks Bill,
    P.S. Is that a Lap day at TMS??
    Nov 2005
    Houston, TX
    3,968
    TWS in College Station. Lots of fun!
    Bill Winters
    Apr 2007
    33
    I have this map sensor can someone tell me how it hooks up to my 05 gto wiring and what I have to change in the E40 and or tune? TIA
    Tuner in Training Ironmancan's Avatar
    May 2008
    Jacksonville NC
    43
    Bump...
    06 Twin Turbo GTO
    Nov 2005
    Houston, TX
    3,968
    It just plugs in...
    Bill Winters
    Tuner in Training c6dude's Avatar
    Oct 2005
    19
    Here is one I made that uses the Mouser electronics unit that is plug and play.
    http://www.dpecorvettes.com/gpage4.html
    May 2009
    479
    Quote Originally Posted by c6dude View Post
    Im using this sensor in my car right now and it seems to work pretty good. Im using a linear of 256kpa(is this correct?) and my factory 1bar setup read 103kpa key on engine off..so I set the offset to 9 to get to the same 103kpa..
    2018 Infiniti Q60s
    2004 350z/LS2: ERL 434ci, 11.8:1,TFS245cc,262/266@113+3,Fast102,NX 102 plate,60#injectors/return w/twin 255s
    Old setup: CNC'd317s, Fast 102, 228/228@114, PT88,83#injectors/full return system. 10.84@138
    Oct 2005
    19
    Quote Originally Posted by Snyper View Post
    Snyper
    The Sensor's range is 20-250kp
    0.2V = 20 kPa - 2.9 PSI
    4.9V = 250 kPa -36.25 PSI
    Accuracy +- 1.5% of the full scale value (+- 0.5 PSI)
    This sensor is linear which makes tuning easier.
    Here is a chart that should help you out.
    Perry
