Results 1 to 7 of 7
Thread: Abuse Mode- Max Torque setting
    Mar 2004
    Long Island NY
    41
    Id imagine it's a good idea to change the default setting from 350 ft/lbs to 450ft/lbs. Is this correct. I have an M6 car with more than 350 ft/lbs of torque.
    02 Z28 M6&&228/230 112 Cam, Flp Long tubes,&&TNT F1, Borla,Spec Stg3, KB SFC\'s, Lca&&Nitto Drags
    Nov 2002
    Central Florida
    2,503
    Re: Abuse Mode- Max Torque setting
    I don't know what this param means - is it the threshold
    for deciding abuse is going on, or is it where the PCM is
    supposed to cap torque output when it declares abuse?
    I sure would like to find a reference that explains this
    sort of thing, what the names really mean and the
    philosophy or behavior of them.
    Im interested in this answer as well.
    99 Hugger Orange Z28 M6
    Lid | Long Tubes | Pulley | LS6 Intake | Ported Tbody
    9" | 4.10's | Torque Arm | Panhard Bar | Lower Control Arms
    337rwhp/339rwtq
    8.355 @ 86.28 / 12.828 @ 110.85 1.971 60'
    04 Black Cobra (Wife's)
    CAI | Catback | Pulley | Ported Eaton
    502rwhp/548rwtq
    track times coming soon...
    Mar 2004
    Long Island NY
    41
    Well i don't think it's where the abuse mode will cap output to because stock it's set to 350ft/lbs. That's usually more than a stock ls1 puts out.
    I have the Manual for my car and I'll see what/if anything it says about the Abuse mode.
    Apr 2004
    East Tennessee
    339
    TTT
    2007 CTS-V LS2
    Mar 2004
    Virginia Beach, Virginia
    24
    I set mine to 639 which is the max the PCM is supposed to recognize. This makes sense since it's the same parameter to remove TM. And in the Torque Reduction tables you zero them out.
    Nov 2002
    Central Florida
    2,503
    I am still having trouble with what (I think) is an abuse
    trigger problem. Under some "spirited driving" event
    my output / RPM will just "limit". This is with a tune
    where I have already done the following:
    Transmission>Abuse Mode RPM 8000
    Transmission>Abuse Mode TPS% 100
    Transmission>Abuse Mode Speed 255
    Transmission>Abuse Mode Torque Reduction
    - table zeroed
    Engine>Enter Abuse Mode Test If RPM> 8000
    Engine>Enter Abuse Mode Test If MPH< 255
    Engine>Max Torque 639
    Engine>Max Torque vs RPM IN Gear
    - table filled w/ 638
    Engine>Abuse Mode Timer vs Trans Temp
    - table zeroed (trying to end this mode quicker)
    I have a question about the
    field, it seems like the sense is backwards (high
    MPH should be abuse?) in the inequality operator.
    Would like some review of this, specifically what
    side of the term makes me -not- trigger abuse test.
    Also, any issue w/ the high RPM and MPH values
    doing a "wrap-around" or anything crazy like that?
