Results 1 to 7 of 7
Thread: DynoTune just released their Wideband!
    Mar 2004
    Long Island NY
    41
    Nice, Dynotune.org just released a wideband for $430. This would go very nicely with my VCMSuite.
    02 Z28 M6&&228/230 112 Cam, Flp Long tubes,&&TNT F1, Borla,Spec Stg3, KB SFC\'s, Lca&&Nitto Drags
    Nov 2002
    Central Florida
    2,503
    Re: DynoTune just released their Wideband!
    Quote Originally Posted by SloppyRob
    Thanks for the link, I've been looking at the Innovate
    one (and staring at the price, waiting for it to drop).
    I'll have to check this one out.
    You might check out the wideband commander from dynojet. It has onboard logging, or loggin via laptop. Programmable relays, warning lights, records RPM, and comes with everything you need. Outputs for other loggin systems etc...
    their support has been fantastic.
    www.dynojet.com
    Xtreme Motorsports has them in stock.
    Nov 2002
    Central Florida
    2,503
    Looking at the three of 'em, it appears that the
    Innovate one (plus separate-option A/F gauge)
    comes in at the lowest overall cost. The Dynojet
    one looks nice but is the most expensive. The
    Innovate and Dynojet both log while the Dynotune
    one says nothing about that (or I missed it). The
    software might make the difference (about $100
    or a little more) worthwhile but it'd have to be real
    helpful.
    May 2004
    ...Somewhere over China....
    53
    Mach V Motorsports sells a Wideband setup with both 0-5v and 0-1v outputs (so you can use the wideband setup with the stock PCM AND get accurate O2 readings with an included external O2 Gauge or separate datalogging system
    All for only $349.00........
    '99 ECSB Silverado 2500LD
    6.0 LQ4|Polished "241" Heads|10.3 CR|VHP "044" cam|HPTuners SD Tune|Pacesetter Headers|Magnaflow Exhaust|Custom CAI|
    May 2004
    Streamwood, IL.
    196
    dumb question, but would you use the wideband instead of the oem ones to use it for the pcm??
    Dave
    Nov 2002
    Central Florida
    2,503
    OEM are switching-style, narrowband units that
    has no temp control and are way inaccurate away
    from 14.7:1. Widebands will be %-accurate out
    to <10:1 AFR.
    The voltage curves are different but most units
    have a 0-1V that you can push into your rear O2
    line for logging (some have only 0-4V that you
    would have to put into the A/C pressure sender,
    or attenuate 4:1, or something like that).
    The wideband electronics may make the signal a
    bit slow for use in the main PCM loop, depends
    on how filtered they make it. The PCM looks more
    for switching events than a level so a slow signal
    might not be soo good. But I guess you could try it.
    Not sure what you'd gain.
