I'm setting my truck up for a 2 stage N20 system and I was wondering if there is a way to use the out puts on HPtuners to control the relays to fire each stage.
I will be using a window switch, but If I could run a program that fired the 1st stage in first gear then the second stage in 2nd / 3rd gear, I would be totally happy.
I think I saw something mentioned about using PCM grounds as grounds to the relays. Could someone fill me in on this?
I figure if I had a NA tune, single stage tune and a 2 stage tune that is preset pulling timing for the hit's of N20 I would A) never forget to pull timing when using the N20 and B) if I did forget to change the tune, well, the N20 would not come on.
BTW, the laptop always is sitting shotgun as it's my guages ect in my 63..
Shaun
