Yes you would need to be logging that mpid.Originally Posted by checkmate
down loaded it. but when i open hpt it still says 2.1.18 on in. did i do it wrong?
You still need to install it after you download it.
i did
just like this? but use the 2.2.0 right.
http://www.thetuningdoctor.com/HPTun.../installer.swf
yup.
cool it works thanks!
Do we have to do a full write to the computer with this new version? I haven't done one since x.14 version on my LS1...
2002 BSM T/A WS6 #3371 (Sept 12, 2002) "LOB"
TSP Tqr II (232/234 113lsa +2), ETP Heads, FAST 90/NW 90, 42#SVO, 25% Powerbond Pulley, FLP catted LT's, B&B Tri-Flo, QTEC, Smooth bellows, Fast Toys 85mm lid & Grn Filter, Lou's SS, LG SFC's + X Braces, LG LCA's, LG PHB, LG DSSL, LG TA, Koni SA's lowered, Z06 Front brakes, Earl's SS lines, IForged Classics (18x9.5" F, 18x10.5" R) & very big and expensive stereo... (Eclipse, Zapco, Focal, Lotus)
No.Originally Posted by WS6Fury
I can't 2.2 to load,I get to run file after I save and it says contact vender.Reason i tryed to add was to tune 08 Z06.It wouldn't let me read that car.I've got Vista on my laptop and did the new updates.Need help.Thanx Also says contact vender to see if this is valid window istallation package.
Check the size of the file, should be around 21-22mb file.
Just to add to this guys we are still actively collecting Ford Files so that we can ensure a more complete launch for the diesel/v6 lines so please send any files you can for
05-07 Ford Mustang V6 4.0
03-07 F-Series Diesel V8 6.0
08 F-Series Diesel V8 6.4
05-07 F-Series Gas V6 4.2
07 F-Series Gas V10 6.8
E-Series as well for the same years as the above F-Series
Thanks for everyones help thus far!
-Bill
Injector Tip Temp is.. a little off to say the least.. I wonder if the tables that reference inj tip temp go by the same value?
Is there an link to download it? I find where to buy it but no link to download it.
www.hptuners.com simply login using your serial number & password, from there you can download the newest software, order credits & view our repository.Originally Posted by blacksi
