The actual calculations are done on a set of 4 dynamnically flow matched siemens 60s on a flow bench with special algorithms written to find the dead time calculations (offsets), linear PW ranges, the adder values needed to bring the injectors back to their linear range in the low PW areas (which for these injectors are all values under 3.75ms) and other info. They are tested using actual gasoline at 120*f. The tests were done for me at 58 psi from 10-16 volts at -120 - 80 kPa VAC. Since I have a returnless system at a constant pressure of 58 psi, I just need to figure out the difference between 58psi@100kPa and 48psi@54kPa for the net difference in kPa between our fuel pressures and I can copy the proper "row" from my table. Just math.
