Results 1 to 20 of 20
Thread: NGK AFX w/NTK Sensor
    Jul 2004
    1,579
    I wanted to verify the accuracy of the NGK gauge display against what HPTuners reported. I am using the NGK AFX wideband with the NTK sensor, not the typical Bosch LSU4 adapted to the NGK. This sensor is supposed to be more accurate and used with the more expensive ECM LambdaPro (from what I have read). I rigged up the HPT to read the voltage output a well, I only logged AFR Cmmd, AFR, AFR Error% and Raw Voltage. I also used the VCM Bi-Directional controls to target an AFR from 8-17. My test vehicle is tuned to the tee, fuel trims are 0% on average throughout the rpm range. Interesting to see that the NTK sensor either wouldn't read higher then 15.8 or the vehcile used was unable to go any leaner. Also the NTK would read as rich as 9.8, but that was the richest the vehicle in question would go (pulse width limit ). I allowed at least 10 seconds for the fuel to stablize before recording the gauge display data. It actually was off no more then 1% from what HPTuners was logging. Pretty impressive sensor, considering the Bosch LSU4 (using an NGK, AEM, and Innovative controllers) has given me results varying largely on the extreme ends of the range, while being .2 off in the 14.5-14.7 range.
    Next time I have time with the "test vehicle" I will have to log pulse width and determine if the vehicle couldn't go leaner/richer then commanded ... or if the sensor couldn't report a lower/higher voltage then specified.
    Disclaimer: This viewpoint is solely based on my experience. It is not intended to be a scientific analysis of the Bosch LSU4 versus the NTK sensor. This was by no means a scientific experiment, but a simple study. Your results may vary.
    Feb 2006
    Canada
    1,958
    I was able to do a very nice job with mine using the same set-up.
    Greg Banish told me to go with that set up and it's been nice for me. My bro just got the pro version for us to play with(mine's old school)and we'll be using this on his Grand Am and his Firehawk. Look foward to getting into the TA I tell you!!!
    Paul
    Jul 2004
    1,579
    Yup, I purchased the AFX on Greg Banish's suggestion, I also opted (now) for the NTK sensor, also based on Greg's suggestion.
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,023
    Now you see why ECM (the actual manufacturer of the AFX) is the standard of the industry? Sometimes it takes and experiement like this to prove the point. I use an ECM LambdaPro for a reason...
    Jul 2004
    1,579
    Greg, If I could afford it, I would opt for the Lambda Pro as well. But glad this setup is much better then what I have previously used. As always your knowledge is always welcomed by me.
    Apr 2003
    Almost 2000 feet.
    7,876
    George,
    Next test will be with all widebands installed on the left collector and all reporting to HP Tuners. Right?
    BTW: That's about what I have experienced when commanding an AFR. Did you try going leaner than 16 to see what the AFX would do?
    Always Support Our Troops!
    Mar 2006
    Detroit
    1,023
    Quote Originally Posted by EC_Tune
    The output/display of the AFX is clipped at 16.0 AFR (lambda=1.1) on the lean side. This is one of the sacrifices ECM made in producing this low cost unit. Since there's really no reason to run this lean in real life, there should be no practical limitation associated with this in the aftermarket "tuning" makret. This unit is still VERY accurate where it counts, between lambda=0.7 and 1.0.
    There are better options if you're genuinely concerned about accuracy in the lean spectrum, like the AFM1000, LambdaPro, or AFM1600.
    Apr 2003
    Almost 2000 feet.
    7,876
    Thanks Greg,
    Hehe -- I just read that too. And you're right, no need for AFR's leaner than 16 (unless you're in DFCO).
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    605
    ... or lean cruise.
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
    Apr 2003
    Almost 2000 feet.
    7,876
    No reason to go leaner than 16 there either according to Greg as it ends up having the same effect as going richer.
    From Houston Stationed in SoCa
    63
    Post I know... back for the dead!
    I have a question then reguarding AFR's with diesel... reading the AFX manual it states that diesel's regularly run leaner than 16 and that it will not display anthing leaner than that....is that to say that the sensor is capable of leaner and if you are logging data using hptuners, that you would still be able to accurately read beyond 16 and that the display is clipped at 16 or what? Maybe diesel tuning is better done with an EGT... I don't know... I'm just asking because I'm in the market for one and will probably play with a diesel...
    All input is welcome...Thanks!
    For anyone interested...I found what looks like a good price for the NGK AFX with the NTK Sensor for $259.99 here: http://hinsonsupercars.com/p-946-ngk...eband-kit.aspx
    Murphy's Laws of War:
    Bullets Have The Right-Of-Way
    Friendly Fire....Isnt
    If It Is Strong Enough The Enemy Cant Get In....You Cant Get Out
    Tracers Point Both Ways
    Jul 2004
    1,579
    The controller will out 16.00 AFR at 5V reference. Any leaner will be outside the controllers output voltage range. The NTK sensor can go leaner, but you need a controller that can output a different 0V-5V scale.
    63
    Okay, that makes sense.... Thanks for clarifying!
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    you think the AFX with NTK would be good enough for a dyno sniffer??
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Aug 2009
    Calibrating
    3,373
    Few quick questions, just received my NGK AFX with NTK sensor
    1.) As the sensor ages what do we need to do to recaliberate it, I know this is one of the cool features of the NGK AFX?
    Edit: seems like I just need to make sure its caliberated about every time I use it? Ir Air_ turn clockwise till it says CAL, and it its Air- turn knob counterclockwise. I believe as long as its used often recal may not be needed, if it sits for a while and then go to tune then yes.
    2.) When using standard HP tuners seems I can just hook the black wire to the body (ground) and the red wire (power) directly to my EGR wire and just power it be enabling the EGR in hptuners, is that correct?
    Edit: Forgot all about the Yellow and Brown wire those seem to be my anolog output wires. So Yellow would go to (in my case Pin 55) EGR wire, and brown I could probably use the same ground as black above. Red (power) from above can be routed to a relay. Hope thats right?
    3. Instead of using a bung, can't I just pull out my 02 sensor on the drivers plug side and and plug this one in, when finished tuning I will just install the factory 02 again.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jul 2004
    1,579
    To answer your questions ...
    1. I have had the same NTK sensor in use for over 3 years now. Sometimes tuning once a week, other times it sat for over 6 months without use. I have calibrated the sensor in free air before use and I have yet to move the dial in the back as it always reads "Cal -".
    2. Red to power, Black to ground, Yellow to input, and Brown to common ground
    3. That is what I always do, remove front driver O2 and place vehicle in Open Loop (either via VCM Controls or in the Editor).
    Aug 2009
    Calibrating
    3,373
    Thanks 12secSS, I have read a lot of your info on this stuff. Learned quite a bit.
    14 Gen 5 Viper
    Feb 2013
    Kozloduy, Bulgaria
    5
    what can be used as standalone data logger wih rpm input for the ntk afx? can it be used with innovate or some other relatively cheap unit, for arround 400-500 usd max ... i just want to log rpm vs afr i have ntk afx, but i dont know what else to buy...
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Innovate has some boxes which do what you want.
    However, if you are not going to use to datalog with hptuners, you can buy a LM-2, it can log rpm from several sources including MSD ignition boxes (useful to log AFR and ROM in carbureted engines)
    9 sec Montecarlo SS
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by A.Dutsov View Post
    HPTuner's Pro in stand-alone mode
    Steve Williams
    TunedbyFrost.com
