Originally Posted by
12secSS
The cats do not have a temperature measuring device for COT to work. It is a calculated threshold programmed into the calibration (which is editable on some calibrations IIRC). What this does is increases the AFR of the commanded mixture to typically 11.7 (1.25). The extra fuel cools the cats and keeps them from boiling over in case of running lean (say 13.0 or leaner). If you have cats, you should command an AFR of at least (leanest) 12.8 to keep them alive. I would only command a leaner AFR after peak torque and no further then peak horsepower, and no leaner then 13.1. Good luck!
