Car is a 382 LS1 8.85Cr with a turbo and stock cam 60lb injectors. I can get the A/f perfect at everywhere I want it, but nothing I change effects idle (10.1 A/f). What values do I need to change to get idle to lean out? Also it is creating some hard start problems. On a side note the second you open the throttle the A/f goes where it needs to be, but when the throttle is at 0% the car gets extremely fat (8.9 A/f on decel) Thanks
