Results 1 to 10 of 10
Thread: 6L80 2014 Caprice PPV TUTD
    Feb 2023
    6
    Hello,
    I'm looking to add TUTD paddle shift to 2014 Caprice PPV via a 2014 Camaro steering wheel. The information I have shows working under Trans/shift general/Tap-up Tap-Down menu, but I can't find that menu when I open my downloaded tune file. Anyway, I've attached my tune file if someone can tell me if I'm just missing something or if my directions may be off, as this is my first try at using tuning software. As far as I'm aware this is a stock tune. Thanks, Jezza
    Tuning Addict
    Jan 2015
    6,813
    Trans - shift scheduling - at the bottom
    ~Greg Huggins~
    Feb 2023
    6
    I must be tired, I still can't find it. Do you see it in my tune file? My instructions are looking for this20230226_201312_2.jpg
    7,647
    Open your tune file. Type CTRL+N (or, Edit > Navigator). Type 'tutd' into the little box.
    Feb 2023
    6
    That found it for me. Thanks so much, I do appreciate it. jezza
    Feb 2023
    6
    One other question, Does this change effect the FSCM? Or can I change it to "Do Not Write" on the FSCM section? The Brickable warning is there. Thanks again for your knowledge, Jezza.
    Jan 2014
    SoCal
    1,562
    Quote Originally Posted by waipunalei View Post
    Won't effect FSCM.
    Correct do not write.
    Only do a write entire when you change something in the OS tab or other operating system modification. Otherwise
    Feb 2023
    6
    Thanks again group.
    Baltimore, Md
    1,208
    Thanks again group.
    Do you have your tune file after you changed the settings and it worked correctly? I have been looking for them, and I think I came across a post on newcaprice.com where a guy had a screen shot but it isnt there anymore and I think you were the last to reply to it looking for the same LOL
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
