I know. I'm just saying... :)
I believe a local shop that's setting up an E85 car is doing a twin in-tank setup, but will be driving one pump full time and letting the FPCM control the other one. We'll see how that works out.
You may see the FPCM pull back the output from the first pump if the second switches on before it's needed.
Guys, I don't know much of what you're talking about in the last couple of posts, but why not use an FPCM modifier like the Magnavolt for Supercharger applications? Wouldn't this boost voltage ultimately throughout the system according to Manifold pressure, or vacuum and bump your Fuel pressure way up there? Or did I miss something.
fuel pump boosters don't work well on new camaros....
I ended up ditching the FPCM and I'm running a setup from ADM. It's the ctsv fuel pump module set up in a return style system.
Both pumps see a constant voltage all the time and it's boosted to 17 with a kb boost a pump when I get into boost.
My recomendation is to go return style and run constant voltage to the pumps. Throw the FPCM out, it's really for emissions anyway. . .
alot of ppl are just ditching the FPCM...pulling it out and deleting all codes via EFI Live or HPTuners.
Did you put the return regulator on the fuel rail or back by the tank like some have done?? What wire did you use to turn on the fuel pump relay?
You don't have to do that. I can probably figure it out when I get ready to do this. I assume its the wire that gets hot or maybe goes to ground for 2 seconds when you first turn the key on. Did you move the pressure sensor up to the rail as well?? thanks
No I didn't move the pressure sensor but since I have the FPCM disconnected it doesn't matter. Without the FPCM hooked up the computer doesn't know the fuel pressure. It just defaults to around 58psi. You need to use a manifold referenced regulator and flatline the IFR table and others.
This all kinda..... Sucks. :( At least you got it figured out.
Here's an interesting thread I just put up on CadillacForums.com:
http://www.cadillacforums.com/forums...important.html
Regards,
James
great post RWTD, :yay: you have always been of great help here, i love reading your informative posts, and i do agree on the table raping thing, i have retuned a few cars that were done by big name local shops and they all had the PE table raped :eek:, i dont get it, it doesnt take that more much time to tune the MAF properly, but o well,might be because they have a flat rate for tuning so the faster they get the car off the dyno the more money they can make i guess??
Check this out, LOL:
http://admperformance.com/data/item_pdf/product240.pdf
WOW, nice of them to put the instruction manual on their site, but to tell you to go paddle up shit creek.
As for the BAP, just ask anyone with a KB setup on their Gen5, as they include easy to understand instructions on how to install it. I'll see if I can't get my friend to scan his.
The 2010 Camaros definitely do have a fuel pressure sensor.
When talking about the pressure falling off... Is that effective pressure or actual line pressure that you're referring to? In all the boosted Camaros I've done, it's normal to see the effective pressure (listed as Inj Delta Pressure) get lower as boost goes up with the returnless setups. At 8psi boost, the Inj Delta Pressure should be 50psi since the FPCM is trying to keep pressure in the rail at 58.
You're exactly right! I had a brain fart last night. It was late. :(
Yeup, you're 100% correct. See my revised post on the Caddy forums, and you'll see that I referenced such.Quote:
Once you'll read that, you'll understand why I'm concerned or curious if the CTS-V2 had a mechanical pressure regulator off the pumps just like the Camaro does. Has anyone seen the basket assembly and can chime in? Steve (Frost)? If it doesn't, then this means that using the Caddy pump assembly/system can/will become insufficient on a higher powered setup, especially forced induction, as well.
The CTS-V assembly has a mechanical relief valve just like the stock Camaro basket. I removed it and put in a solid machined plug that ADM supplied to ensure this valve isn't opening with my higher than stock fuel pressure. I'm not sure at what psi the stock valve is set to though
