LM-1 not syncing up with HPT
I installed the bung just after the collector on the drivers side, wired in the LM1 output to the PRO interface and did a scan. with the preset LM1 setting and the premade HPT PID i was about 1. off on afr EX. if the LM1 display was at 14.7 the HPT might say 13.6ish. I reprogramed the LM1 to the 0v-10afr 5v-18afr output setting and made a new custom pid in HPT for the WB going off soundengineers thread with i beleve it was .625v at 10 well now im showing like 10.4afr in HPT while the LM1 disply will read 14.7 i adjusted the PID up 4.3 points and it matched while idling but was way off at any other point. can/will one of you life savers help me configure my LM1 to work with my HPT so i can do some WOT tuning at the track tomorrow. I tried searching but didnt find anything that would help.I tried several sugestions i found, but with no success.
