VCM Write Failed
An error occurred during the write process.
CAUTION: DO NOT pull your VCM's fuse or disconnect battery power in an attempt to correct the problem.
Follow these guidelines:
1. Make sure the vehicle has sufficient battery voltage for programming.
2. Make sure your laptop has sufficient power.
3. Make sure all communications cables are connected firmly.
4. Restart VCM Editor.
5. Open the same file you wrote to the VCM when the error occurred. It is very important that you use the same file.
6. Try to Write VCM again.
7. If the problem persists, contact customer support. See Contacting Customer Support.
