What is Pro Feature Set?
The Pro Feature Set is an enhancement to MPVI2 and MPVI2+ that takes the capabilities of these interfaces to the next level. Pro Feature Set is standard on MPVI3.
At present, purchasing the Pro Feature Set adds the following features:
Support for Pro Link and Pro Link+
Standalone Data Logging
Additional features are planned.
The Pro Link and Pro Link+ are cables that allow additional inputs to be connected to the MPVI2, 2+ and 3 for enhanced data logging. This allows you to see these additional signals in VCM Scanner, potentially providing critical insights into how your tune is performing.
Pro Link allows you to connect up to two analog signals (such as a wideband sensor or a map senor) and one CAN bus signal to an MPVI2.
Pro Link+ allows you to connect the same inputs to an MPVI2+ or MPVI3.
When you purchase the Pro Feature Set for your MPVI2/2+, we will send you the version of the Pro Link cable that supports your interface.
Although Pro Feature Set comes standard on the MPVI3. The Pro Link+ cable must be purchased separately for this interface. To order, go to https://www.hptuners.com/product/pro-link-plus/.
See Standalone Data Logging for more information.
