Table Editor Right-click Menu
Right clicking on a table in the table editor displays the following options:
Copy
Copy a selected cell or section of the table to the clipboard.
Copy with Axis
This function copies a selected cell or section of a table and includes the axis data. When used in conjunction with the Paste Special function, Copy With Axis allows the data to be pasted into another table without selecting the destination cell. Because the data was copied with axis labels, the software will automatically place the pasted data accordingly.
NOTE: This is similar to the function in VCM Scanner's Graph panel and RTT Editor.
Paste
Pastes a cell or table section into a selected cell. When pasting a copied region, the selected cell will become the top left cell in the pasted region.
Paste Special
This function pastes data copied using the Copy With Axis feature into the current table.
The contents of the clipboard must be of the same dimensions as the contents of your table.
Add
Add the contents of the clipboard to the table
Subtract
Subtract the contents of the clipboard from the table
Multiply %
Multiply the contents of the table by the clipboard values as a percentage
Multiply % ‑ Half
Multiply the contents of the table by the clipboard values as a percentage divided in half
Average
Average the values between the clipboard and the table
Import From File
Export the selected cells to a file. Data is saved in the .csv format.
Export To File
Import a range of cells from a .csv file.
Column Axis
Includes options to copy the labels from the column axis and edit the column axis, or change the units of the column axis.
Row Axis
Includes options to copy the labels from the row axis and edit the row axis, or change the units of the row axis.
