Expression Variables
When entering expressions for virtual measurements, variables are used to represent the output of a individual sensors and other measurements.
Adding a Variable
Follow these steps to add a variable:
Click the Parameter link. The Parameter Selector window appears. |
Double-click on the PID or sensor that you wish to use for the variable. |
In the Unit dropdown of the Variable Wizard window, select the unit you want to use for this variable. |
If you want to use a special function (modifier) for the variable, select the desired function and then enter the associated Period in milliseconds. |
NOTE: If you know, the internal name of the measurement you want to add, you can type it directly into the Math Expression box as text.
