Results 1 to 14 of 14
Thread: 4.8L with fuel trim issues please someone review this log🙏
    May 2024
    7
    Truck has a btr stage 2 cam.
    5BA8
    3,561
    Well, judging by the wealth of information you've provided, looks like it has split fuel trims. If the ONLY modification to the vehicle is a BTR stage 2 cam, looks like you has some problems.
    You might want to let it get up to operating temp before you get too wrapped up in what it's doing when it's cold.
    email=[email protected]
    May 2024
    7
    Gimme a few and I’ll update
    May 2024
    7
    Tune file and log is in attached, purchased this truck off of a guy with just idea that it ran but not good clearly. Appreciate the help!
    5BA8
    3,561
    Your pid list is terrible. Use the attached channel list for data logging. If you don't know how, search how to download, save and open a channel list.
    Bank 1 fuel trims are pegged positive which means it's adding as much fuel as it can on that side. You don't have O2s in your data so I can't see what they look like but I'd bet you have a bad O2 sensor or the whole bank is dead, something like that.
    Do you have a temp gun? Infrared point and shoot temp gun? If not go down to Harbor Freight and grab one. They're cheap nowadays. Need to check your exhaust manifold temps.
    Bottom line you need to figure out why bank 1 has the trims maxed. There's no tuning that will fix that.
    P01 DBC.Channels.xml
    May 2024
    7
    Do I need to buy credits to flash this thing back to stock to see any change?
    Arizona
    512
    Quote Originally Posted by Tylerhether View Post
    once you buy credits and unlock it. Thats it, that computer and that ECM are married for life.
    5BA8
    3,561
    That depends how you want to approach that. But flashing it back to stock won't fix your split fuel trims. I'm telling you that's not something that can be fixed by tooning. Put your laptop and interface down and figure out mechanically what's different between the banks. It's bad so it should be pretty obvious.
    5BA8
    3,561
    Quote Originally Posted by bk2life View Post
    Yes but if you want to flash a completely new file to your PCM unless you have unlimited credits you will have to license the new file to flash to your already licensed PCM.
    May 2024
    7
    Okay I got it back but that bank is still not producing,O2 sensors are working. Short term bank 1 still maxing out and long terms are doing nothing.
    May 2024
    7
    I’ll break into it when I get home and see what I see.
    Arizona
    512
    O2 sensors are working..
    are you positive the O2s are in the correct spots?
    sometimes they get switched and the left bank is reading the right bank
    May 2024
    7
    Alright new plugs and new o2 sensors here is a log.
    2,968
    P0036 - HO2S Heater Control Circuit (Bank 1, Sensor 2) (Pending, Current)
    P0050 - HO2S Heater Control Circuit (Bank 2, Sensor 1) (Pending, Current)
    P0056 - HO2S Heater Control Circuit (Bank 2, Sensor 2) (Pending, Current)
    P0443 - Evaporative Emission System Purge Control Valve Circuit (Pending, Current)
    P0449 - Evaporative Emission System Vent Control Circuit Intermittent (Pending, Current)
    P0452 - Evaporative Emission System Pressure Sensor/Switch Low (Pending, Current)
    P0740 - Torque Converter Clutch Solenoid Circuit / Open (Pending, Current)
    P0785 - Shift/Timing Solenoid (Pending, Current)
    P0054 - HO2S Heater Resistance (Bank 1, Sensor 2) (Pending)
    P0059 - HO2S Heater Resistance (Bank 2, Sensor 1) (Pending)
    P0060 - HO2S Heater Resistance (Bank 2, Sensor 2) (Pending)
    You have a lot of codes that need attention.. sepcifically on the o2 issue anything that says sensor 1.
    The passenger side sensor looks like it might be shorted to ground or something is off.
    Tuner at PCMofnc.com
