Results 1 to 16 of 16
Thread: c6 Z06 LS7 Knock retard False Knock ??!
    Oct 2018
    27
    Hello guys i need your Help My car has a lot KR i don't know what the problem is.
    Car has approx 45k miles and has H/C/I and Tune from katech i dont change anything, and the car runs fine, but for the past 6 months i have had issues with KR.
    I don't drive so much often, approx. 2?3k miles in the year with this car, and i run only 102 octane pump gas fuel ( in USA, like 97?98 octane)
    I Already changed all spark plugs and checked the spark plug wiring.
    And make compressions test it was very good on all cylinders over 15 bars!!!
    Thanks a lot for your support.
    Greetings form germany
    Jan 2023
    NY
    273
    Post your tune as well
    Oct 2018
    27
    Sorry I forgot, but I can say it's not the tune fault !? Because I have older log without any KR. C6 Z06 Halil Katech Original Datenstand#.hpt
    https://drive.google.com/file/d/1WFV...ew?usp=sharing
    here is my old log same tune what I see is my car is running a lot leaner than before in this log i don't logged the AFR with hp tuners because I was to dump for this at this time.
    But what I saw it's approx from 79-81.
    I think It has issues with the fuel pump on this car !!
    5BA8
    3,525
    Do you have a catch can on the car?
    First thing I would do is an "induction service". Suck some Seafoam into the intake while running. It'll clean all the oil out of the intake and de-carbon the cylinders, tops of the pistons. Then blow the engine out good. See if that doesn't fix it.
    If it doesn't have a catch, put one on it.
    email=[email protected]
    2,922
    Quote Originally Posted by hy_bmw_freak View Post
    Sometimes they just go bad. Have you tried a set of new GM knock sensors. Don't buy anything else.. Beware of counterfeits on amazon and ebay.
    I assume you don't hear any knock audibly?
    Tuner at PCMofnc.com
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    233
    The old seafoam trick. I remember when I was young and tuning peoples DSM's I would do this all the time. My neighbor used to get so mad saying I was destroying the environment. HAHA. Another reason I love e85. Pistons and valves stay so clean, unless direct injected.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
    5BA8
    3,525
    Quote Originally Posted by JayRolla View Post
    It's about the only chemical "fix" I've seen that actually works.
    Oct 2018
    27
    Thanks a lot for the support guys
    I already checked my msd Intake and resealed.
    Yes I have already catch can.
    But I would say the failure goes in right fuel pump for me bc knock comes always if the lambda goes to like .90 and on my old logs car runs a lot richer and my heads are milled too
    I will order new gm fuel pump and change both oem knock sensors.
    Oct 2018
    27
    No I don't here any knock sounds the car is to load for this but a feel the powerlost and car runs like it has fueling issues
    5BA8
    3,525
    Judging by the narrowbands it looks plenty rich enough not to be knocking on 97 octane fuel even if it's higher compression. It by no means looks lean.
    Oct 2018
    27
    yes i know but do you see my old log ?? it runs a lot richer but i dont know if is that the problem or not...
    Jul 2012
    Florida
    1,481
    Looks a little lean
    2013 Silverado 5.3, 6L80k 8.8
    Oct 2018
    27
    Looks a little lean
    Why you can't see my wideband log ???
    5BA8
    3,525
    When I posted this ^^^^ I had looked through his 250 pids for a wideband and couldn't find it. That's why I referred to the narrowbands.
    Looks a little lean
    After reading this I went back and looked again and yes it looks leanER than it's commanding and leanER than I'd like it to be.
    What concerns me even more is the amount of timing commanded right around peak torque. My opinion it's a FEW degrees too much ESPECIALLY for a higher compression LS7 EVEN on higher octane fuel. It's commanding 25.5 degrees at 4000 RPM. I'd bet on a dyno it would stop gaining at 21 degrees at that point. I haven't looked at the tune file but the data log looks like the timing peaks at peak tq. and then goes back down. Typically the opposite of what you'd normally do which is roll the timing back at peak torque and then back in after you pass through.
    I'd drop the timing through peak tq. for sure. By 4 or 5 degrees. The combo of both too much timing and little lean on fuel is the kiss of death. I pray for OPs ring lands LOL
    Arizona
    268
    Im jealous at the amount of advance some of these LS7s are seeing in places with better fuel. Unfortunately, here in phoenix, our 91 octane is basically piss water. I typically max out at 18-20* advance on LS7s with H/C/I on 91 octane. In the middle of the Phoenix heat (110-118 degrees ambient), most of the H/C/I LS7s see about 14-16*s after the IAT does it job. So sad
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Mar 2021
    233
    Like edcmat has said have you tried to pull say 4-5* timing out around the 3600rpm and up just to see if it helps with the knock. Might be a bit spicey at max tq even with the octane.
