Results 1 to 9 of 9
Thread: 2018 Ford Mustang GT DFCO Not Triggering After Hard Pulls
    May 2024
    6
    removed
    removed
    Sep 2023
    3
    This should fix it. I also edited the MAF Airflow vs Period using the data provided by your datalog.
    18 MUSTANG GT 5.0.hpt
    May 2024
    6
    removed
    May 2024
    6
    removed
    Mar 2006
    Detroit
    1,038
    Log your load and inferred exhaust/cat temp.
    You are probably seeing it try to avoid melting hot fuel-loaded cats with raw oxygen (whether you have them or not), along with protecting the O2 sensors and exhaust valve temps.
    May 2024
    6
    removed
    Mar 2006
    Detroit
    1,038
    Good, now look carefully at your logged temperatures, and then go back and look at the temperature thresholds (in the calibration file) to allow DFCO based on them.
    May 2024
    6
    removed
