Page 5 of 5 FirstFirst 12345
Results 81 to 90 of 90
Thread: Lost injector info
  1. #81
    Tuner bsaathoff73's Avatar
    Nov 2023
    Nebraska
    53
    was so much better. Not near as many pops and were kinda stretched so I got to run it to 187.Around 180 is where it began to pop more and more. Thats when I shut it down. Pretty damn excited over here.
  2. #82
    Mar 2022
    Indiana
    3,072
    Are you sure the initial spark timing is correct? I'm having to give it a lot of advance at idle, and that's what you're seeing as improvement. How did you go about integrating the optispark with the 0411? Most people do a delete.
  3. #83
    Nov 2023
    Nebraska
    53
    Ok. So i think im stupid or im not remembering. Probably both. I have to look at some things i did prior to you with the others. As im looking here now. I may not have my coil connected right. I think its set up when there was a ignition box on it. So one side of the coil isnt hooked up right now.
    Holy hell
  4. #84
    Nov 2023
    Nebraska
    53
    Yes. Its set for the damn ignition box still. I apologize. i will start on it now.
  5. #85
    Nov 2023
    Nebraska
    53
    Pop after 150 degrees. 16 until I shut off. Not near as many. More closer together towards the end
  6. #86
    Mar 2022
    Indiana
    3,072
    Try this real quick.
  7. #87
    Nov 2023
    Nebraska
    53
    sorry. Ran in to my uncles.
  8. #88
    Mar 2022
    Indiana
    3,072
    Alright well it's responding to fueling commands. That's what I wanted to check. Rough adjustment to VE here.
  9. #89
    Nov 2023
    Nebraska
    53
    had to hold tb open a bit to start it. Let go and it shuts off
  10. #90
    Mar 2022
    Indiana
    3,072
    I dunno man. This is about the last thing I can think to do.
