Thread: Engine breaking/DFCO or off throttle timing?
    Jan 2024
    18
    Engine braking/DFCO or off throttle timing?
    Help me understand this as I might be mistaken the two. I have been playing with off throttle timing by lowering it in an attempt to get a mean burble from the exhaust on deceleration or coasting in my ls2 GTO. I used to have it ever so slightly but it seems to have gone away. The GTO just doesn't sound as mean when compared to my jeep 392 running a livernois tune. Don't mistake this for me wanting pops and bangs. Just a nice growl when downshifting or coasting to a stop.
    Am I confusing DFCO and engine braking with off throttle timing?
    Tuning Addict
    6,882
    You need to post the tune file, but you might be.
    Basically for just a gurgle while not losing all engine hold back you need to raise your percent max brake to hold the throttle open a touch more then set your dfco crank references really high to enter dfco then adjust your timing how you want it. Doing these - when adjusted right - will hold the throttle ever so slightly more open allowing air to flow better through the motor while not cutting fuel.
    ~Greg Huggins~
    Jan 2024
    18
    Appreciate the feedback. Please disregard the spelling in the title. Dang phone auto filled and I didn't catch it.
    I will take a closer look at the dfco. I think it is set somewhere around 3800rpm to enable and 2400 to disable. Not positive but I will look.
    Thank you
    Jan 2024
    18
    Engine Braking/DFCO or off throttle timing?
    My tune attached.
    Don't judge
