Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 90
Thread: Lost injector info
  1. #61
    Mar 2022
    Indiana
    3,055
    Here it is for wideband tuning. Dial it in with narrowbands after you get the B2 issue sorted.
  2. #62
    Tuner bsaathoff73's Avatar
    Nov 2023
    Nebraska
    53
    Im out there now checking it out. Harness tested ok. So now gonna look at the pcm and make sure wiring is correct.
    Thank you.
  3. #63
    Nov 2023
    Nebraska
    53
    Wiring is in correct spots. I'll look how to check signal from pcm.
  4. #64
    Nov 2023
    Nebraska
    53
    heres 2 scans. I have no idea whats going on.
  5. #65
    Mar 2022
    Indiana
    3,055
    Try again.
  6. #66
    Nov 2023
    Nebraska
    53
    I always shut off after a few pops. I dont know if i should keep logging for a bit or... Heres todays scan.
  7. #67
    Mar 2022
    Indiana
    3,055
    Alright that's better. Wideband is AEM 30-4110?
    Follow this procedure. Especially the "Increasing Closed Throttle Body Airflow" part. IAC counts are maxed out.
    After that do another log. Include the channels Equivalence Ratio Commanded generic and TPS voltage.
  8. #68
    Mar 2022
    Indiana
    3,055
    Ffs sorry about that. Here's the link.
    https://www.pcmofnc.com/2021/03/05/i...throttle-body/
  9. #69
    Nov 2023
    Nebraska
    53
    here is a new log. I drilled a hole just smaller then stock size. Hopefully its better
  10. #70
    Nov 2023
    Nebraska
    53
    3/16 hole
  11. #71
    Mar 2022
    Indiana
    3,055
    Had the effect we wanted. Are you able to back the throttle stop off? I'd like to see TPS voltage being close to 0.45V as possible.
  12. #72
    Nov 2023
    Nebraska
    53
    tb backed out to where I can see a gap between the screw and accelerator arm. Sounded better. Temp got higher before popping. drill bigger? Its a 3/16 now.
  13. #73
    Mar 2022
    Indiana
    3,055
    You backed out the screw yet TPS voltage didn't change. Is the screw still on the stop? When you moved the screw the throttle moved with it?
  14. #74
    Nov 2023
    Nebraska
    53
    Yes. Completely backed out. I dont think the blade moved at all.
  15. #75
    Nov 2023
    Nebraska
    53
    I can stop at menards tomorrow after work n get a 32nd bigger. just let me know.
  16. #76
    Mar 2022
    Indiana
    3,055
    Quote Originally Posted by bsaathoff73 View Post
    Yeah see that's why. Move the stop in until the throttle just starts to crack open. Throttle should rest on the stop not the blade. Give it another 1/2 turn.
    Perform throttle relearn.
    Don't drill just yet. Let's see how it does.
  17. #77
    Nov 2023
    Nebraska
    53
    I will do this today after work. Pry around 7 or 8 tonight. Thank you.
  18. #78
    Nov 2023
    Nebraska
    53
    I put the screw in a bit. Then did a half turn. Can see blades got tiny crack now. No change on the volts.
  19. #79
    Mar 2022
    Indiana
    3,055
    That's good on TB adjustments for now. Let it idle up to operating temp if you can.
    Tell me about what all has been done to the ignition system.
  20. #80
    Nov 2023
    Nebraska
    53
    I apologize. For ignition i think of key n timing. Key. Nothing. Timing. Should be set right. Motor was built at a reputable shop. Timing. Msd coil, msd opti. 411 swap. Im pry off on what you meant.
