Results 1 to 2 of 2
Thread: 4L80E swap in Hummer H2 TCC problem
    Mar 2021
    Iceland
    5
    4L80e Swap in Hummer H2 TCC problem.
    Hi, I did transmission swap in my H2. Everything working just fine, no trouble codes but when oil reaches 185 deg F the TCC stops working, everything normal up to that point and as I said before no trouble codes. Have you guys exspirienced similar problem..? What could be the problem..? Is there some setting in the map that I'm missing out..?
    Best regards,
    Boggi
    1,580
    You are half way to the instructions given in the other post you made. Now the log half.
