Results 1 to 2 of 2
Thread: TCC Desired Pressure
    Sep 2018
    Norway
    I would like to change some TCC settings for my L20/6L90 swapped 1993 S10 Blazer.
    The engine and transmission are from a 2014 Express van, and it is a E38 ECM.
    I can?t understand the ?TCC Desired Pressure? (TCM 5672).
    Some values are set to zero, and max value is 52. The PCA range is 0-168 Kpa.
    All instructions I have looked at, shows PCA range 0-1600 Kpa.
    I would like to enter similar values as a 2012 Camaro ZL1, where the values are set to 79-1330 Kpa.
    Can someone explain this difference in PCA range? I guess I can?t just copy the ZL1 values and paste it to my tune, as long as the range mismatch?
    Thanks,
    Roy
    Australia
    2,001
    might be better to post this in the GM V8 transmission section so more people see it
