Results 1 to 12 of 12
Thread: Idle timing erratic (1999 JTEC)
    Jul 2021
    45
    I've been messing with this for a while. It was dyno tuned by a shop in Kennesaw Ga. The tune wasn't quite correct, so instead of keep paying them hourly to keep messing with it, I bought a MPVI2 to try my hand at tuning it. The JTEC platform is really basic as compared to other platforms. I've had some help from a few guys here on the forum (Thanks [email protected] and hexdummy for sharing some knowledge). Engine is a 5.9, 9.6:1, edelbrock heads, 218/226 @.050 525/525 lift, 112 installed @ 108. Stock intake, stock injectors, dual 2.5 exhaust, nothing crazy.
    Fuel trims look dialed in. I'm not real sure about the main timing table the tuner set up. It looks really conservative. I may mess with that some later on. One of the things I've noticed is my idle timing on the VCM scanner is all over the place. Since the computer controls timing, what could be causing this? The IAC fluctuates also. Vacuum at idle is 14hg and is steady. Compression test on all cylinders is 175psi. this is a new engine i built. Cam was installed with a degree wheel so i know its installed correctly.
    idle_ac_run.hpl
    Jul 2021
    45
    Jul 2012
    Colorado Springs, CO
    42
    Did you ever figure anything out on this? Mine does weird stuff too and I don't understand why.
    Did you perform an idle sync?
    5BA8
    3,604
    Both behaviors are perfectly normal. It uses both the IAC and timing to control idle speed. Neither are supposed to be steady @ idle.
    Idle synch has nothing to do with it.
    email=[email protected]
    I got a hotter 5.9 that his and mine idles fine with a slight lope, it doesn't hunt for a steady idle. If it's hunting for an idle something with that small cam, something isn't set up right.
    5BA8
    3,604
    Quote Originally Posted by EvilR/T View Post
    I got a hotter 5.9 that his and mine idles fine with a slight lope, it doesn't hunt for a steady idle. If it's hunting foe an idle something with that small cam, something isn't set up right.
    It's not hunting for an idle. The behavior of both the IAC and the timing are completely normal.
    This is the table for your idle spark. "Proportional gain for idle spark based on RPM error". All EFI systems use spark to control idle speed. The IAC is supposed to move constantly also.
    Totally misread that, sorry. Yes, all that in mine is moving around too, PCM is consistently adjusting.
    Jul 2021
    45
    This tuning stuff is all new to me, and there?s not much info for the JTEC platform. Can you explain what these number mean in this table?
    Jul 2021
    45
    I thought the same thing, that?s there something wrong with the engine. I did a compression check, all cylinders were 175. I did a leak down check and all cylinders were near zero. I?ve about had it with this engine. I?m about to pull it out and tear it down. Hell I might just replace it with a Hemi and a stand alone EFI system like a Holley sniper.
    Maybe I'm missing the problem, is your RPM at idle jumping around or is it steady and your see the jumping around on the datalog?
    Jul 2021
    45
    I had Chris Jensen do an email tune last year. He fixed my idle problem. I'm not sure what program he used but he made changes and emailed them, and I used HP Tuners to download the tune. Since then, everything was fine, until lately. For no reason my idle would jump from 750 to 1200-1500...just sitting at a red light. The idle wouldn't settle back down until I turned off and restarted my truck. It wouldn't do this all the time, just randomly for no reason. I did find a couple loose exhaust manifold bolts. I tightened them up but haven't been able to drive and data log since I tightened them. I really wish there was more info out there about the old JTEC, and what some of the parameters meant in HP Tuners program.
    Oh yeah, one more thing sometimes the A/F ratio would go super lean at idle. The A/F gauge would go lean beyond what it could read and just go to dashes and the truck would almost stall out. Id hit the gas and it would recover for a minute and go lean and almost stall again.
