i have 2007 suburban with a HP tune in it,the computer went bad replacing it with new flagship one plug and play. can i pull my tune off with hp tuner and reload it into the new computer
You will want to copy the changes from the old tune to the new tune read from the new ECM. The write calibration back to the ECM.
So are you able to help me program as well
NoOriginally Posted by [email protected]
we would NOT recommend flashing a file from one ecm to a different ecm, you do so at your own risk.
What your recommendation after install my new ecm
If your computer went bad, how do you plan to read the tune off it?
A bad computer isn't going to let you read it 99% of the time.
You can install your new computer and start tuning it yourself.
well im getting transmission code low circuit low solenoid, discover problem in ecm vehicle still drive able just has transmission code
when you say tune myself i have hp tuner but very little experience
Sounds doubtful that you have a bad ECM. If it is, sounds like it’s probably still readable.
read new ecm, license, & tune away using the file you read and licensed from the new ecm. This is also outlined in the help file.
