I'm curious as to why it only has 17lbs boost @ 8900rpms.
I thought it would be way higher than that.
Because of AIT and rpms 8850 with another 100 rpms i seen 18psi waiting on a custom prop to gain rpms and boost
The 24 325 just needs more rpms to build boost at 9200 i seen 21psi on my first test
yeah 142s 19psi but check ait 105 deg the flat front of the wheel disturbs the air producing more heat vs the normal style wheel with velocity style nut smoother colder air just like then new 2024 for example i bet i could beat your ski on 19psi of boost and my 325 on 18psi
