Results 1 to 7 of 7
Thread: Fuel tank drain 2017 Mustang
    What would I change in the fuel pump tab to get the pump to constantly run to drain the tank? Running stock PWM pumps.
    Oct 2016
    Poland
    1,777
    Nothing as fuel pump in 2gen is BCM driven. Short 2 pins under the seat or wire a switch.
    I changed fuel pump>pump command signal>off duty cycle to 49% and the pump runs constantly. tank is drained
    Oct 2016
    Poland
    1,777
    Quote Originally Posted by Davem3261 View Post
    Must be a one off case as this never worked for me in any mustang no matter what is set there.
    Lund gave me a tank drain tune. His works, logged it and the pump ran constantly at 49%. I was curious how it worked. I put the mustang at 49% drained that. Did the same with my F150 to go back to pump gas.
    Oct 2016
    Poland
    1,777
    Might be this works in the lund's OS - who knows It never did for me.
    Anyways this got me curious, might try again and hook up an oscilloscope.
    I modified my stock file so it was using the stock OS
