Originally Posted by
F150Farmer
I tried it out, works great. you'll need to change drive modes to 65535. Then to choose what drive modes you want it to be used in, change duration on the drive modes that you would like enabled. 15 is the baja mode in the raptors and stock, its set to 30 sec above 2000 RPM. I found that if the RPM is set too low, you can get some backfiring when you get back on it. For the other drive modes, 0 is normal, 2 is sport, 10 is slippery, 15 is baja. Anyone know what rock crawl, tow modes, depp snow/sand are?
