Results 1 to 11 of 11
Thread: 2013 Cadillac ATS 2.0 LTG Auto 6 Speed P0138
    Oct 2017
    Az
    10
    First off new to this GM platform
    Recently purchased a 2013 Cadillac ATS 2.0 LTG auto 6 speed. Previous owner did not maintain the vehicle to IMO proper standards. Previous owner had vehicle serviced at a mom and pop shop and should I say "Butchered" the vehicle with replacing parts NON OE and band aid solutions. Since ownership of vehicle i've replaced.....
    MAF - GM OEM
    VVT - Intake/Exhaust - GM OEM
    MAP - GM OEM
    BARO - GM OEM
    Spark Plugs/Coils - GM OEM
    VAC PMP/Hose's/All Valvecover seals/ evap valves on valve cover -GM OEM
    O2's - GM OEM, Down stream Aftermaket "autozone" Walker
    Cat/Exhaust - ZZP highflow/Exhaust complete
    Catch Can system - ZZP
    Spent numerous hours trying to get the car to just driver as factory for daily driver. My question is due to DP/Exhaust do I need to start tuning due to this or am I missing something. Datalog's what seems as if to many. Just curious to see if other LTG owner's have had the same issue's.
    0x7E8: P0138 - O2 Circuit High Voltage (Bank 1, Sensor 2) (SES, Pending, Current, Old, Permanent, History)
    0x7E8: P013A - O2 Sensor Slow Response - Rich to Lean (Bank 1 and Sensor 2) (SES, Pending, Current, Old, Permanent, History)
    0x7E8: P013E - O2 Sensor Delayed Response - Rich to Lean (Bank 1 Sensor 2) (SES, Pending, Current, Old, Permanent, History)
    0x7E8: P0299 - Turbocharger/Supercharger A Underboost Condition (SES, Pending, Current, Old, Permanent, History)
    0x7E8: P0138 - O2 Circuit High Voltage (Bank 1, Sensor 2) (Pending, Current, Permanent)
    0x7E8: P1101 - Mass Airflow Sensor Out Of Self Test Range (Pending)
    0x7E8: P013E - O2 Sensor Delayed Response - Rich to Lean (Bank 1 Sensor 2) (Pending, Current, Old)
    0x7E8: P1101 - Mass Airflow Sensor Out Of Self Test Range (Pending, Old)
    0x7E8: P0113 - Intake Air Temperature Sensor 1 Circuit High (Pending)
    0x7E8: P2227 - Barometric Pressure (BARO) Sensor Performance (Pending)
    0x7E8: P2228 - Barometric Pressure (BARO) Sensor Circuit Low Voltage (Pending)
    Want to get the vehicle stable before Tuning. Any input is great.
    Oct 2017
    Az
    10
    Sorry forgot to upload
    Dec 2008
    Nevada
    4,452
    High voltage on the O2 is usually indicative of running rich which is evident by the other codes P013A. The second code is telling you it has made an attempt to lean it out but the car isn't responding as it thinks it should.
    When changing the airflow model by physical part replacement you always follow up with a tune. The engine may or may not perform better than before, but the new parts often change installed sensor responses and effect their calibration curves. These calibrations have to be corrected to bring the engine fueling back into range in most cases.
    If the hardware was installed correctly and all major engine internals are still OEM including the Turbo, then it should run fine without a tune and let you drive around without too much issue as you make your way to the dyno for a proper calibration. The use of non-OEM parts isn't really a big deal as long as they are functioning. Ive ran Walker Exhaust O2 Sensors and NTK Sensors without any change in performance (when verified functioning).
    From the sounds of your post you didn't install the exhaust so if I were you, I would be questioning the installation and also looking into the sensors to make sure the pinouts agree between sensor and ecu. If thats not right, no ecu adjustment will ever make the O2 signal change.
    Oct 2017
    Az
    10
    Thank you for the response. I did install the exhaust and everything myself to factory torque specs via alldata info. Figured the vehicle would have auto corrected by now, yet hasen't literally the only thing i havent touch is intake manifold and timing chains. Smoked it nothing. Do I throw a bung on it and start tuning? Never seen such a stuborn car. Thanks again Cobalt!!
    Dec 2008
    Nevada
    4,452
    I'm afraid i red your initial post too fast and gave you a bad answer. In a more detailed look, your O2 codes are all for sensor 2. When you overlay B1S1 with B1S2, you see that S2 follows B1 with a small delay. If the Three Way Converter (TWC) was working efficiently, B2 would be less responsive and more averaged (smoother and flatter fluctuations).
    Are these codes you read after deleting the codes and performing a drive cycle?
    Lots of historical codes. Sometimes reading codes right after a reset is helpful because teh immediate offenders pop back up teh fastest which can help point you in a direction.
    From your log, the fuel trims at idle are under 10% combined, so the engine is running well according to the sensor feedback. They seem to be on the positive side but not anything i would consider explanation for codes.
    Oct 2017
    Az
    10
    Thank you again cobalt.
    Cyl 1 Comp test 154 psi 10 cycle starts via starter
    Cyl 1 Leakdown @ 50 psi 49 psi under pressure
    Cyl 2 Comp test 154 psi 10 cycle starts via starter
    Cyl 2 Leakdown @ 50 psi 49 psi under pressure
    Cyl 3 Comp test 156 psi 10 cycle starts via starter
    Cyl 3 Leakdown @ 50 psi 49.5 psi under pressure
    Cyl 4 Comp test 156 psi 10 cycle starts via starter
    Cyl 4 Leakdown @ 50 psi 49 psi under pressure
    Factory exhaust has been replaced with the zzp aftermarket setup so it does not have the TWC that is on the factory setup. @ idle code right away but normal driving sensors balance out with a +/-. Im just curious with having the aftermaket exhaust and not having the TWC it that the cause of said issue. willing to buy the Wideband and go from there tho is the restrictive STOCK exhaust the helper with the TWC or since new zzp is a little free flowing exhaust the cause of the issue? Spark plug change to AC DELCO 41-988 GAPED @ .028Spark plug change ats8123.hpldrive to get kids.hpl
    Oct 2017
    Az
    10
    Vehicle cannot complete drive cycle. tried 1 forced drive cycle and 1 regular just to see WTF
    Dec 2008
    Nevada
    4,452
    So it has ZZP exhaust. Does it also have their catalytic converter or have the converters been removed completely?
    If this has the ZZP converter, does the post-converter O2 sensor have an adapter threaded onto it or is the sensor installed directly into the downpipe? (O2 adapter circled in red)
    From your log files, the B1S1 says the engine is running pretty good at this time. Majority of the time within 5% trims which isn't really worth touching.
    All your issues pertain to the post-converter sensor. If you have the ZZP converter installed and the TWC element is in tact, I'm thinking you are either missing the O2 Sensor restrictive extension fitting or you have a converter on the frits.
    Oct 2017
    Az
    10
    Yes it does also have that exact cat on the vehicle and the adapter is also in place. The cat has 729 miles on it since installed. It throw's code's on startup and idle, but driving after its heated up thing's balance out. 20230630_160924.jpg
    Apr 2024
    Maf
    I know you said you replaced the maf with oem parts, but by chance did you make sure it's the one with the iat sensor built in? I had the same situation and that's what I found to be my problem. After replacing most of what you did I finally read that and got the right one.
    QUOTE=zetec_influenced;739018]First off new to this GM platform
    MAF - GM OEM
    MAP - GM OEM
    BARO - GM OEM
    Want to get the vehicle stable before Tuning. Any input is great.[/QUOTE]
    May 2024
    3
    im having a similar issue similar mods i was getting the same code until i installed the 02 restrictor i had the 90 degree restrictor but it tossed a code in about 10 miles post cat stuck lean
    and now i have p2097 with Stright restrictor
    when i used to tune v8 cars with headers i could just adjust the ve and o2 voltages this hasn't worked on the ltg i get about 400 miles before it pops on now im starting to think the only option is disable the codes
    i also just got the maf out of range but i played with the voltages on the last tune
    some of your codes sound like you have a vac leak check the pcv system the catch can can trigger a code and also check the vac lines under the car
    you will need to clear your permanent code with something like a vx nano as it uses the gm software
    the mpvi cannot clear the permanent codes even after a repair
    underboost can be set from the care entering reduced power mode from it seeing the other o2 codes my car did that with multiple failed bank 1 sensor 2 codes
    also the p2227 and p2228 can be a leak around the map sensor under the throttle body check the gasket
    basically you have multiple codes that are current and all revolve around a vac leak somewhere
    that causes the engine to run lean prompting the computer to correct and give you a rich exhaust condition
