Results 1 to 12 of 12
Thread: Intake Cam out of control ? - 2021 Coyote S
    Jun 2023
    4
    Hi all, curious if anyone has seen this, I'm new to coyotes. 2021 Mach 1 is throwing a MIL for P0345 Cam position sensor bank 2. Datalog shows what appears to be a loss of cam control after initial warm up. Bank 2 intake cam varies much more than bank 1 and I assume after much of that or varying too far off course it then pops the fault code. Once the fault code is set it parks the cams at 0.
    At cold start up (first graph) you can see the bank 2 intake cam (4th line) is not as steady as bank 1 intake cam (3rd line) which follows the desired timing (2nd line). You can also see the duty cycle for bank 2 is much more active than bank 1, bottom two lines.
    After warm up (second graph) it appears to lose control or just give up and then fault sets, top line.
    Is this a classic bad phaser on bank 2? I ask because this engine only has 8k miles but its not 100% stock. We built an aluminator clone short block for it using the GT500 oil pump and pan. That pump has a higher pressure at all RPMs than the stock pump. Could this be giving me issues? You'd think both cams would be unhappy if that were the case.
    Background - Engine was rebuilt due to a spun rod bearing which was caught fairly early. Phaser screens did have a small amount of debris. New screens were installed and cams and heads cleaned. One head with scored journals replaced, other head was ok.
    Thoughts? Appreciate any insight you might have.
    Thanks, Mike
    Apr 2020
    Moline, IL
    82
    I recently had something similar to this. I replaced the solenoids first without any effect. Ended up being a the phaser.
    Mar 2022
    Indiana
    3,070
    Could be a bad part. From a control standpoint there is too much gain for the current system (that system being the phaser, oil pressure, oil viscosity).
    Adjust Feed Forward DC table for that cam.
    If problem persists it might be the cam phaser, but it might be too much clearance on a cam journal.
    Feb 2017
    TX
    761
    Always been the cam position sensor when I ran across that.
    Aug 2010
    Detroit, MI
    981
    Don't adjust anything in the toon... Replace the part.
    Jun 2023
    4
    Thanks for the feedback so far. I should add that cam sensor was replaced already, easy quick, cheap, but no change. Also since the service manual diagnostic for P0345 took me down the path of an intermittent connectivity issue I swapped the harness with a known good harness. No change. It was after both of these that I data logged. Should have done that first.
    Mar 2022
    Indiana
    3,070
    Quote Originally Posted by smokeshow View Post
    Which part would that be, dick? All that is known is that the issue is oil pressure-related. Phaser? Better be sure. It takes a lot more to tear into one of these motors than an LS.
    Adjusting the toon can reveal a bad part. It might not be bad though. If adjustment doesn't do anything or the problem comes back then yeah phaser. Better than playing the parts lottery.
    Or there could be something else bad but not worth replacing if the toon can compensate. One head was changed due to excessive wear, the other wasn't. So if one is on the loose side, and adjusting DC fixes it, totally worth it.
    https://www.autoserviceprofessional....e-may-set-dtcs
    "Wear in the thrust bearing cap could be the cause of the variable camshaft timing (VCT) setting DTCs due to oil leakage as a resulr of excessive clearance in the bearing cap. This in turn will not allow enough oil to feed the VCT Phaser for proper operation."
    Let's see...adjust toon (free) or $3.5k in parts and labor. Hmmm.
    Maybe even try something like 5w-40 Quaker State Euro.
    Jun 2023
    4
    Running 5w-50 and with the GT500 pump I’m seeing 25psi at hot idle and 80-120psi off idle.
    Aug 2010
    Detroit, MI
    981
    I love when people come back and rage-edit their posts.
    Mar 2022
    Indiana
    3,070
    I love when people rage-PM about "mansplaining".
    Oct 2016
    Poland
    1,771
    Quote Originally Posted by Mjschneidy View Post
    The only difference in that pump is a vale relief spring so they build up more pressure. GT350 has a stiffer spring too.
    Jun 2023
    4
    GT500 pump has a wider rotor for more volume too. If I can figure out why I can?t attach a jpeg I could show a side by side pic of the pump rotors, it notably wider. (Getting error messages with attachments)
