Results 1 to 7 of 7
Thread: What should I do with a new ECU
    May 2023
    20
    I?m going to buy a E40 ECU soon got 2 questions. Do I need to take it to the dealer? Do I need 2 key fobs.
    Only reason I?m buying a new one is the ECU that?s on there now is tuner locked if anyone knows how to bypass it please let me know.
    I?m not stock either. I have a cam, headers, cold air intake, nos
    SoCal
    1,633
    You will need the initial programming at the dealer level. HP Tuners does not write all the needed software. As to other programming it may be best to start over on the add ons.
    Aug 2020
    335
    Sounds like you will be starting with a stock file in either situation. You can just reprogram the one in there now with dealer tools and save on buying a new computer.
    2,988
    We have a ECM unlocking service and also can reprogram with GM SPS software for your new module.
    If the module is locked GM software will not over write it either.
    Tuner at PCMofnc.com
    May 2023
    20
    It?s only the ecu don?t have a tcm since it?s manual would that be okay?
    SoCal
    1,633
    Quote Originally Posted by Manny16 View Post
    He will be able to do it. TCM w/without won't matter.
    2,988
    I cannot unlock TCM's. I'm not sure I've ever seen one locked. Could be wrong.
    Just unlock PCM/ECM
