@2xLs1
They are Delphi 12613412 flex fuel injectors which should be 52lb injectors at 58PSI. I am running a returnless fuel rail with a corvette fuel filter. Fuel is ran via 3/8in ptfe fuel lines and 3/8in steel hard line.
@Hondaeater
Its raining right now so I logged a real quick in the garage (this car isnt ever going to see rain). See attached.
My MAF is failed and has been for quite some time as I have been working on my VE table.
No it wasn't failed in previous tune posted.
Built 4l60E transmission with BW clutches, 4l79 3-4 drum with 12 clutches... the whole 9 yards and connected with a 9in precision industries single disk torque converter set to 3200 rpm.
injectors are delphi 12613412
Im not sure what flare control you are referring to
There was positive numbers in the flair control at startup.
Yes i have AC installed and I just finished hooking it up. I have had the rough idle long before the AC but it is worsened by turning on the AC (will kill the engine sometimes).
I havent had problems with the E Fan before but I will go back and relook it. Im running a Ford Tauris with the volvo relay. It really doesnt cycle that often as the low setting will cool it quite well. Only time the high kicks on is spirited stop and go traffic.
Very close ON-OFF degrees sometimes makes the relay cycle unless it has a hard time ever getting to the OFF cycle and just stays ON all the time. 2 degrees to turn on or off and only 5 degrees between the two fans is tight tolerances. If it works for ya leave it but if the relay goes out I would change it.
Responses in the quote.
I forgot to change the base cylinder volume. It should check out now. My understanding is that should help out some as it is essentially increasing the ve table by .04.
Nope it REDUCES the VE table when you raise the Cylinder volume.
If you hit the details tab under channels list it shows the status of MAF.
NOW it is Failed and why you may have been having poor results trying to tune a VE table in blended mode, both MAF and VE.
Not good data without those channels I posted. You have a lot of channels that are not going to help you. Very curious why the EQ commanded is not populating? It is the commanded eq from ecm that is the same as the AFR but in Lambda?
If you get time, download my channels I posted and save your current channels using the floppy icon then use the gear folder icon to load the posted channels. Make a new log using them as you cannot change the channels list once a log has been made it must record the channels from the list upon making it.
