Hi All. First time LS swapper trying to learn as much as I can. I'll take any advice/direction/feedback I can get on where to go next on tuning.
My setup is a 2001 LQ4 and 2006 4L60E swapped into a 91 Camaro. I did a block up build (first time) and used mostly the stock assembly. Local guy sold me his LS6 intake, Cam, and injectors (BR3E-EB) from his 2005 CTS-V (5.7L). Speed Engineering Long Tubes and Holley dual exhaust.
Using the stock 411 PCM and used TunerPro/PCM Hammer to delete VATs, O2, & EGR. Segment swapped a 4L60E in place of stock 4L80E that was in the 2001 2500HD.
Got the engine in and started it up with the stock LQ4 tune and the thing ran super rich. Not having a clue at what I'm doing but trying to research and try getting this thing driveable. My first edit was to take a stock 2005 CTS-V tune and copied most of the tune over (see Edit Tracker file). Next start up seemed to idle better and was driveable but didn't feel great. Looked to be still extremely rich and I assume if was the difference from stock LQ4 28lb injectors and the 36lb injectors I bought used. Edit 2 was to reduce injector rate by 15% and also disabled trans abuse. It was much more drivable but now I'm trying to figure out what to do next.
The research continues but I'll take any advice I can get. I know I got a lot to learn but also would like to get this making progress while I do the research.
Attaching my Edit Tracker, Base Tune, Edit 1 Tune, Edit 2 Tune, Edit 1 drive scan, Edit 2 drive scan, and reference 2005 CTS-V tune.
