Results 1 to 10 of 10
Thread: new turbo build wont start please help
    Jan 2016
    47
    2002 silverado 5.3 ss2 70 lb injectors 78/75 billet 1.25 a/r
    Jan 2016
    47
    if i put the NA tune back in it starts right up
    7,912
    Applying the custom OS fills that with nonsense data, you need to give it real data for it to run.
    Also need to verify MAP sensor linear/offset match the actual sensor being used, those get changed to defaults too.
    Jan 2016
    47
    ok ill look at the table but where do i find the info for the map im using a duramax one from the same year truck
    7,912
    You need either real data for those injectors, or if that's not available, different injectors that come with real data.
    I looked for your MAP sensor but couldn't find anything.
    Maybe if you had a part number? But be aware, if it's not one that's commonly used in swaps the linear/offset may not be published anywhere.
    Mystery parts with no data are not a good fit for the stock PCM. Might be better off with a Holley where you pick parts from a drop-down menu, they are built for stuff like this. The stock PCM is not.
    Mar 2011
    Ripley, MS
    1,865
    Here's your tune with the Duramax MAP sensor data and a typical turbo VE table for your application.
    It should get you running. However, you will need to find the proper injector data in order to get it dialed in 100%.
    lucy 2 bar 7578 tbss 92 tb changed fuel table KW MOD.hpt
    13,599
    I wouldn't use a duramax map sensor but that's just me.
    Mar 2011
    Ripley, MS
    1,865
    I agree. There are way better options. If you're staying below 15 psi, the ol Cobalt 2 bar sensor is hard to beat.
    1,558
    Why not the Duramax sensor? Loss of resolution? I'm using a later model Duramax 4 bar map sensor (GM part #12612110) on my LNF Cobalt Ecotec (actually an ATK LHU/LNF replacement long block w/ intake and sensor) in my kit car at up to 24psi. This is also the sensor used in some of the Buick and Cadillac models.
