Thread: 2007 classic Silverado Flex Fuel OS 12597120
    Jan 2012
    12
    Im looking for a file for a 2007 classic silverado OS# 12597120 my truck is currently an L59 (Flex Fuel) but it does not have the actual sensor, its calculated. Im installing the sensor but need help tuning it for an actual sensor. Wondering if there were any tunes out there with this OS that actually had the sensor?
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    405
    2,380
    All 06 and 07 Classic L59s were Virtual Flex. Just toggle the Fuel Sensor switch from Not Fitted to Fitted and enable the DTCs for the sensor. You can look at a 05 L59 to see which ones. There are upgraded OSs from GM for 07 L59s for improved Virtual Flex. 12619624
    8,049
    Before you put in a lot of effort might not be a bad idea to check if there's a newer OS. 1259xxxx for a 2007 is a good indication it's pretty old. --> https://tis2web.service.gm.com/tis2web/
    Jan 2012
    12
    Ok I did that, it appears to be reading now. I'll need to out some corn in it to be sure tho
    -John
