I would like to be able to control the operation of the dual stage oil pump in my supercharged Canyon so that it comes on under certain boost conditions.
At present the factory programming shuts off the oil pump control solenoid at 4500 rpm which activates the "second stage" high pressure, higher volume.
While a simple switch or switch and relay could allow this control manually it would be nice to be able to control it through programming.
Reason for wanting this is the piston squirters only operate at 50-55 psi and above which most of the time is below the first stage oil pressure (typically 37-45 psi hot).
Second stage oil pressure is typically 80-90 psi using 5W-30 oil.
Manual control would be OK if not ideal as the time I would want to use it most is climbing a long grade towing at 3500 rpm under boost for example.
