Results 1 to 3 of 3
Thread: Jeep wranger ls swap l92 map sensor issues
    Nov 2019
    5
    I'm having issues getting the vehicle to run correctly my map sensor is reading 36.9 constantly, is there a way to just delete the map sensor and run the engin3 without it. I checked the wiring and the sensors are good I've tried 3 different sensors and theyre all doing the same thing
    7,921
    'checked the wiring' means what? If you 'checked' it and didn't verify that you can jump +5v to the signal wire and see it change in the scanner, you haven't really checked it yet.
    What is your pinout? What's the application?
    Mar 2011
    Ripley, MS
    1,865
    Which MAP sensor and ECM are you using?
