Results 1 to 3 of 3
Thread: VCM MPVI firmware 4.8.7 SCANNER NOT CONNECTING TO LM-2 WIDEBAND HELP PLEASE
    May 2021
    7
    I have MPVI interface that was working with lm-2 wideband.
    I read a vehicle and it prompts me to update.
    after the update I can add the channel, I can see lm-2 options I have the calibrations of 1024-0.5 volts out.
    Once I start Record it disappears.
    firmaware 4.8.7 PMVI interface
    firmaware 1.8a lm-2 wideband
    2002 ecm/pcm/ecu gm truck
    please any help will greatly appreciated it .
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    332
    Are you using the Serial or analog out from the LM-2? I had the same problem last year where the serial connection would cause the PID to disappear. There is also the problem of the analog out not being a true analog signal but a PWM signal that the MPVI reads and displays as a bunch of garbage data that we cannot use. I build a digital to analog converter and run that between the LM-2 and the MPVI. I then set up the LM-2 on one of the 0-5V analog inputs in the Scanner and is works great so far. I got the information on how to build the box from this thread.
    Mar 2010
    Goleta CA
    122
    You are not alone.
    See this thread elsewhere on this forum.
    Hib Halverson
    Just Another Tuner in Training.
