Trying to help a friend dial in his 2013 Mustang GT. It has headers, x pipe, cold air intake, and is on E85. This is a stick car. It currently runs 12.6 in the 1/4. I am use to tuning on LS type PCMs and LT1 OBD1 PCM so I am a little lost here.
1. Which table controls timing? There are 15 tables in Borderline and MBT??
2. Which graph set up should I use with the VCM scanner for this car for knock?
3. Which graph set up should I use with the VCM scanner for this car for spark timing?
3. Is there anyway to make the factory wide band show in the VCM scanner?
4. What is the ideal AFR on these cars for E85?
5. What is the best timing for E85 on these cars at WOT?
6. Should the TPS read a % at idle? This one reads 14.1 or so % at idle.
Thanks for any help :-)
